Kirjoittaja Aihe: Spektrum DX8  (Luettu 129498 kertaa)
Paikalla Maikko
Vs: Spektrum DX8
« Vastaus #175 : 24 Toukokuu, 2015, 23:01:43 »
Huomasin että Spektrum DX8:lle oli tullut yli vuosi (Feb 19, 2014) sitten Version 3.01 päivitys, joka oli mennyt itseltäni ohi. Laitoin sisään.
Version 3.01
2014 Feb 19
Software Features
SpektrumTM DX8 AirWareTM Change Log
• Enabled support for LiIon transmitter battery as an option on the System Settings screen.
• Enabled support for V-Tail B (electronically swapped ruddervator servos)
• Added access to the System menu directly from the Function menu.
• Added the ability to reverse Flap System controls for analog-style inputs
(Knob, Left and Right Trimmers)
• Updated telemetry to include the GPS Distance calculation found in our
higher radios.
• GPS supports a “home” altitude. This cannot be used to generate an alarm at
this time, but it does make it easier to understand altitude above ground level. At the GPS status screen, press CLEAR to set the altitude to 0. This will also set the “home” position for the Distance calculation.
• Telemetry “Settings” menu has new option to auto-populate the list of sensors reporting from the model at the current time.
• Telemetry filename now defaults to the model name. It is NOT retained through a power-cycle or when changing the model.
• Hidden Apple Mac files and directories are not listed in the SD menu screens.
• The telemetry menu has been added to the Function list.
• The Spektrum Vario Sensor SPM9589 may be used to report altitude data.
The radio does NOT support the vario functionality, only the altitude reported
by the vario sensor.
• Sailplane mode supports the trainer button as a Flight Mode switch option.
Software Corrections
• In Sailplane mode, the camber system now properly supports a smooth trim change on elevator between different flight modes.
Poissa Genneli
Vs: Spektrum DX8
« Vastaus #176 : 11 Joulukuu, 2016, 14:13:09 »
Osaisko joku neuvoa miten dx8 mankasta saa korjattua välyksen pois kaasun/perän ohjaustikusta perän osalta? Ymmärtääkseni sen jotenkin saa, onko kukaan kyseistä operaatiota tehnyt?  :)
Poissa Kallo
Vs: Spektrum DX8
« Vastaus #177 : 12 Joulukuu, 2016, 23:33:19 »
Mää olen tehnyt.
Takakansi irti, kuitenkin ensin pitää irrottaa takakannen kumiset kädensijat koska osa ruuveista on muistaakseni niiden alla. Kumit lähtee ehjinä varovasti repimällä, vetämällä ja suostuttelemalla. Youtubestakin löytyy varmaan oppaita DX8:n avaamiseen. Sitten sisältä löytyy gimbaalin jousien kiristysruuvit joita tiukkaamalla välys häviää. Kierros tai pari riittää, ei kannata ylikiristää ettei sormituntuma muutu.
« Viimeksi muokattu: 12 Joulukuu, 2016, 23:36:49 kirjoittanut Kallo »
Poissa Genneli
Vs: Spektrum DX8
« Vastaus #178 : 13 Joulukuu, 2016, 06:32:28 »
Thanks! :)
Poissa juba
Vs: Spektrum DX8
« Vastaus #179 : 14 Tammikuu, 2018, 16:43:30 »
Iltaa. Mulla DX8:ssa sellanen ongelma, kun laittaa lähettimeen virrat päälle kuuluu pitkä piippaus ennen kuin lähetin käynnistyy. Piippausta ei tule joka kerta. Kun lähetin piippaa ennen käynnistystä se ei pindaa välttämättä konetta. Mitä tuo pitkä piippaus tarkoittaa ennen kuin lähetin käynnistyy?
4261 Lukukerrat
Uusin viesti 08 Lokakuu, 2011, 13:50:43
kirjoittanut zenix
34 Vastauksia
19280 Lukukerrat
Uusin viesti 05 Huhtikuu, 2015, 09:28:11
kirjoittanut Konna
5959 Lukukerrat
Uusin viesti 30 Maaliskuu, 2016, 23:35:59
kirjoittanut masala
6650 Lukukerrat
Uusin viesti 04 Kesäkuu, 2016, 15:26:11
kirjoittanut okallio
1955 Lukukerrat
Uusin viesti 16 Elokuu, 2016, 01:44:01
kirjoittanut virtakuono
