Kirjoittaja Aihe: 450:sen 6S ja 500:sen 12S akut  (Luettu 16196 kertaa)
« : 15 Maaliskuu, 2012, 19:16:19 »
Listaa sopivista akuista siis..
TP1300-6SPP65 Thunder Power G6 Pro Power LiPo 1300mAh 6S 22.2v 65C suit 6S 450 size helis AUD79.99
Toistaiseksi tilattavissa vain tuolta http://arkrc.com.au/tp1300-6spp65-thunder-power-g6-pro-power-lipo-1300mah-6s-22-2v-65c-suit-6s-450-size-helis/
98mm * 31mm * 35mm
210g
Maximum Continuous Discharge    65C
Maximum Burst Discharge    130C
Maximum Continuous Current    84.5A
( 80 Australian dollars = 63.1607384 Euros  :o )
Align 6S1P 22.2V 1100mAh/40C HBP11001 $32.99
http://www.align.com.tw/shop/product_info.php?products_id=4301
http://www.fast-lad.co.uk/store/hbp11001_6s1p_222v_1100mah-p-19761.html  €28.62
34x108x25.5mm
195g
Voltz 1300mAh 6S 22.2V 35C Lipo Pack VT130035C6S €40.71
http://www.fast-lad.co.uk/store/voltz_1300mah_222v_lipo_pack_vt130035c6s-p-14178.html
75mm(L) 35mm(W) 44mm(H)
210g
Galaxy 6s 22,2v 1300mAh 40C-80C €38.72
http://www.innovationrc.it/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=824&category_id=95&option=com_virtuemart&Itemid=135&vmcchk=1&Itemid=135
70x35x23mm
230 g
Turnigy 1300mAh 6S 35C Lipo Pack $21.99
Buddycode: http://www.hobbyking.com/buddy.asp?code=8D67191F-3342-49C8-BAB0-0AA83BC717D9
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=20963
76x35x46mm
234g
Turnigy 1300mAh 6S 25C Lipo Pack $18.76
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=20962
76x35x42mm
221g
Turnigy nano-tech 1300mah 6S 45~90C    $25.12
http://www.hobbyking.com/hobbyking/store/__22907__Turnigy_nano_tech_1300mah_6S_45_90C_Lipo_Pack_450_helicopter_HK_Trex_Rave_E4_etc_.html
75 x 35 x 47mm
223g
Turnigy nano-tech 1300mAh 6S1P 35~70C Lipo Pack $23.99
http://www.hobbyking.com/hobbyking/store/__23919__Turnigy_nano_tech_1300mAh_6S1P_35_70C_Lipo_Pack_450_helicopter_HK_Trex_Rave_E4_etc_.html
106 x 34x 29mm
215g
Turnigy nano-tech 1300mAh 6S1P 25~50C Lipo Pack    $20.99
http://www.hobbyking.com/hobbyking/store/__23918__Turnigy_nano_tech_1300mAh_6S1P_25_50C_Lipo_Pack_450_helicopter_HK_Trex_Rave_E4_etc_.html
104 x 34 x 29mm
206g
Gens Ace 22.2v 1200mAh 6S1P 20C/45C Li-Polymer battery w/ T connector $25.90
http://www.rc711.com/shop/gens-ace-222v-1200mah-6s1p-2050c-lipolymer-battery-connector-p-5818.html?cPath=280_278
100.8 x  28.8 x 20.3 mm
189g
Gens ace 1200mAh 22.2V 40C/80C 6S1P €28
http://www.gensace.com/epages/genspow.sf/en_GB/?ObjectPath=/Shops/genspow/Products/B-40C-1200-6S1P
Suomesta: http://www.eurorc.com/product/2332/gens-ace-1200mah-222v-40c-6s1p-lipo-battery-pack   29,90€
105 *34 *30 mm
229g
Opti Power Lipo Cell Battery 1300mAh 6S 50C
http://www.fast-lad.co.uk/store/opti_power_lipo_cell_battery_1300mah_opr13006s-p-21329.html €51.04
C Rate Continuous.............. ...25
Max Burst C Rate...................5 0
Reccomended Charge C Rate...1c
Max Charge C Rate.................3c
75mm x width 42mm x thickness 35mm
210g
Gens Ace 1400mAh 22.2V 40C 6S1P
Saksassa: http://www.gensace.com/epages/genspow.sf/en_GB/?ObjectPath=/Shops/genspow/Products/B-40C-1400-6S1P 31.20 €
Suomen linkkiä odotellessa...
Continuous discharge rating: 40C (80C max burst)
Charge rating: 1-3C recommended (5C max)
Balance Plug : JST-XH
Charge plug: T-plug
254g
107mm x 33 x 34mm
« Viimeksi muokattu: 29 Marraskuu, 2012, 20:03:32 kirjoittanut jkkmobile »
Poissa 338federal
  • Kerranki lentokuva.
Vs: 450:sen 6S ja 500:sen 12S akut
« Vastaus #1 : 15 Maaliskuu, 2012, 20:43:32 »
Kohta täytyy tehdä tilaus Hobby kingiltä  ;D
« Vastaus #2 : 16 Maaliskuu, 2012, 05:58:29 »
Asiaa sivuten pysyykö lentoajan samoissa lukemissa ku 3s:llä?
« Vastaus #3 : 16 Maaliskuu, 2012, 08:28:13 »
äkkiseltään ajateltuna voipi jopa nousta!
isompi jännite -> pienemmät virrat -> paremmat hyötysuhteet joka komponentissa ;)
« Vastaus #4 : 16 Maaliskuu, 2012, 09:23:52 »
Näin kuvittelisin kans mutta totta tuota joku on jo käytännössä verrannut  ???
Poissa Tonsku
  • RC-Kopterit ry #31
« Vastaus #5 : 16 Maaliskuu, 2012, 10:15:33 »
Ainakin mitä olen helifreakista asiasta lukenut, niin kehuvat selvästi pidentynyttä lentoaikaa ja siltikin tehon pysymistä vakiona koko lennon ajan. Ja sitä tehoa kanssa piisaa... Näin siis ainakin 450 koossa. Voip olla että tulee tällä kaudella testattua omassakin porossa 6s setuppia.
Futaba 14SG
Facebook
« Vastaus #6 : 16 Maaliskuu, 2012, 10:31:44 »
Juu rupes itteeki kiinnostaan tuo 6s... kesäksi pitäs uusia akkuja ostaa..
Poissa katti
« Vastaus #7 : 16 Maaliskuu, 2012, 14:13:43 »
Moottorin KV-arvon pitänee olla pienempi sitten samassa suhteessa, eli millaIsta moottoria on ajateltu ?
Tietenkin, ihan nyt elektroniikan kannalta, jos on jonkinlaisella ohjelmoitavalla virtarajalla oleva säädin
niin silloin pitäisi entisenkin moottorin toimia. Jännitehän ei moottoria tapa vaan virta. En vain ole
sattunut mistään näkemään RC-käytössä virtarajalla olevia säätimiä.
TREX-500 2*HK450PRO-DFC
« Vastaus #8 : 16 Maaliskuu, 2012, 14:22:05 »
Joo, motin kv pitaa olla puolet pienempi.. esim: http://www.trex-store.com/450mx-harjaton-moottori-1700kv-rcmbl450mx-p-2903.html
Ja noparin tulee tukea 6S akkua, esim: http://www.fast-lad.co.uk/store/castle_phoenix_lite_brushless_csephxicel50-p-9755.html
Poissa supaman
« Vastaus #9 : 16 Maaliskuu, 2012, 15:00:15 »
Tässhän tuota olis 450 kokoselle 6s-setti jonka hinnalla ei putoa kauheen korkeelta jos ei satukkaan miellyttämään..
http://www.rc711.com/shop/3dpro-450-high-voltage-upgrade-combo-p-5435.html
Esky Belt cp V2(arkistoitu)
TT Raptor 50T FBL with BeastX
Hitec Aurora 9
Poissa 338federal
« Vastaus #10 : 16 Maaliskuu, 2012, 15:44:40 »
Mulle tulee 1700kv align. Kontronik jazz ja tupla 3s1300mah akut. Hobby kingiltä tulee varmaan tilattua noi 1300 6s.
Poissa peksa
« Vastaus #11 : 16 Maaliskuu, 2012, 19:28:39 »
Tuleeko paksuudesta vielä haittaa, meinaan pitääkö sijoitusta muuttaa vs 3s ?
HK 450
Futaba FC-18
Poissa 338federal
« Vastaus #12 : 16 Maaliskuu, 2012, 21:06:18 »
Mulla tuli parempi tasapaino 6s setupilla. Tavaliseen 450 voi olla liika etupainossa. Mulla on toi Tarot 480 stretchkit. Ihan jees. Lentoa en ole vielä 6s tehny. On aika uus tää mun align koppu ja mennään vielä 3s orkkis.
Poissa artta
  • Parolan LK
« Vastaus #13 : 22 Maaliskuu, 2012, 07:59:05 »
Jaa, hoppykinky on vastannut asiakkaiden huutoon:
1300 mAh 45-90C 6s Nanotech
Futaba 8FG
« Vastaus #14 : 26 Maaliskuu, 2012, 21:51:00 »
listaan lisätty 65C Thunder Power 1300mAh 6S! Mulle mulle mulle!
« Vastaus #15 : 27 Maaliskuu, 2012, 15:11:29 »
Paivitin tietoja TP akuista listaan..
..eli: Kysyin ARKRC:lta akuista, vastaus: "This is real we had them custom made by Thunderpower very nice batts for 6S 450 setups !!! "
Eli toistaiseksi tilattavissa vain tuolta.. toimittavat suomeen.
Poissa Tonsku
Futaba 14SG
Facebook
« Vastaus #17 : 31 Toukokuu, 2012, 14:31:16 »
Poissa DM
« Vastaus #18 : 31 Toukokuu, 2012, 15:28:06 »
Gens ace 1200mAh 22.2V 40-80C 6S1P 28€ / kpl Saksasta
Tuolta ei taida saada tilattua Suomeen?
mCPX brushless | DX7
Poissa zxiicci
  • TLR-Insraktori
  • Lajin helppous viehättää!
« Vastaus #19 : 31 Toukokuu, 2012, 15:46:13 »
EuroRCltä pitäisi kohta saada Gens Ace 6s 1200mah akkuja ja kattavasti muitakin  helikoptereihin sopivia Gens Ace akkuja :)
Poissa zenix
  • RC-Kopterit Ry #0236
« Vastaus #20 : 31 Toukokuu, 2012, 21:54:19 »
EuroRC:stä tuli sutjakasti GensAcet. Jos ei näy varastossa niin kannattaa kysellä sähköpostilla.
« Vastaus #21 : 31 Toukokuu, 2012, 22:34:26 »
Joku sanoi, että saisi. Itse olen kanssa omani ostanut EuroRC:ltä. Hinta hyvä ja palvelu pelaa!
« Vastaus #22 : 31 Toukokuu, 2012, 22:41:04 »
Jeep, eli EuroRC:n kautta pitäs saada aika hyvin s-postia vaan kehiin, akkuja pitäis olla tällähetkellä tulossa, pitäs olla joskus kesäkuun puolessavälissä suomessa :)
« Vastaus #23 : 13 Kesäkuu, 2012, 14:20:06 »
Uudet nanotekit lisätty listaan.
Huom koko ja paino, nyt siis normi 3S akun kokoisinakin:
106 x 34x 29mm
215g
104 x 34 x 29mm
206g
« Vastaus #24 : 31 Lokakuu, 2012, 13:23:46 »
Opti Power Lipo Cell Battery 1300mAh 6S lisätty
Ymmärtääkseni genssiltä tulossa myös 1400mAh vaihtoehto...
3125 Lukukerrat
Uusin viesti 31 Tammikuu, 2011, 21:31:58
kirjoittanut J@ni
2560 Lukukerrat
Uusin viesti 29 Kesäkuu, 2018, 17:11:59
kirjoittanut HeliFlyFinland
2916 Lukukerrat
Uusin viesti 13 Maaliskuu, 2019, 06:18:42
kirjoittanut Wilikki
3010 Lukukerrat
Uusin viesti 18 Huhtikuu, 2020, 13:58:35
kirjoittanut madman
3550 Lukukerrat
Uusin viesti 07 Maaliskuu, 2021, 17:29:27
kirjoittanut Laitman
