Joku lightweight malli tullut Maxista, pätee sekä Evoon et perus malliin. 240 euroa upgrade kitti.
http://shop.msheli.it/Item.aspx?IDItem=965The Protos Max V2 Leggero leverages the industries most robust and technologically advanced platform, but removes a staggering 350g from the Max V2 design. The end result is an unmatched experience in light weight performance yet incredible strength. The Max V2 Leggero is ready to elevate your hobby to new heights of performance and fun.
Utilizing new composite materials, many components of the Max V2 Leggero have been updated to remove weight and elevate performance. With the updated design it's now possible to build a world class 700 machine with unparalleled robustness below 12lb (5.45Kg). Yet the Max V2L retains the strength to support 770 and 800 configurations. The legendary twin belt design carries incredible power, while removing the noise, high maintenance, and vibration caused by traditional designs.
Features:
Updated super light weight bottom frame (changed from Ultralight)
Lightweight "Gorilla" landing gear included. Gorilla gear take abuse, and are nearly indestructible
Lightweight battery tray
Lightweight main gear
Lightweight front tail pulley
Main shaft modified for reduced weight
Lightweight aluminum motor pulley
Lightweight canopy mounts with pre-installed gromets
Configurable as a 700, 770, or 800. 770 or 800 options require inexpensive conversion kits
Innovative gear-less twin belt design. Ultra robust. Ultra quiet. Ultra efficient.
Tail belt auto tensioner using a full spring implementation for extreme durability and consistency.
Large rear tail pulley to dramatically improve tail authority and belt life
Compact all metal head design with integrated pitch reference. Capable of handling extreme loads in an 700/770/800 configuration.
Ultimate tail holding power and ease of tuning with a 4.8 ratio and mechanics to handle 115mm tail blades at high RPM
Brain2 Flybarless System included. Ground breaking performance, tuned by some of the most technically minded pilots in the world. Ultra simple wizard for setup.Full telemetry, logging and rescue capability.
