Kirjoittaja Aihe: MSH Brain FBL gyro  (Luettu 97050 kertaa)
Poissa samiwhat
  • TLR-Tiimipelotti
Vs: MSH Brain FBL gyro
« Vastaus #175 : 27 Helmikuu, 2016, 20:32:26 »
Tää on sikäli ihan pirun hyvä jeti miehille uutinen sillä käsittääksen toi jeti integraatio on vuorossa tän rescuetoiminnon jälkeen brainin kehittäjiltä.
« Vastaus #176 : 06 Kesäkuu, 2016, 22:33:32 »
2.0 firmis ulkona uudella rescue toiminnolla.
Release Notes:
- 2.0.000 (Firmware 2.0.000)
- In some case, when Spektrum satellites are binded by software, setup is defaulted: Fixed
- Added in the “Connections” panel of the Wizard, also schematics for uBrain2 miniBrain2 Brain2, Brain2BT, Brain2HD, Brain2HDBT
- Added in “Demo Mode” the uBrain2 miniBrain2 Brain2, Brain2BT, Brain2HD, Brain2HDBT in the unit selection
- Auto level algorithm completely revised and now is self-configured and auto correct itself
- Removed “Set Level” button from “Unit Orientation” panel of the wizard (now is automatic)
- Removed “Aileron angle for hovering” and “Elevator angle for hovering” cursors (now are automatic)
- Removed “Auto Level” checkboxes from “Flying Style Setup” panel of the Wizard
- Added in the Wizard the new panel “Rescue Mode Setup”
- Added the ability to activate the Auto Level with positive pitch increment (Auto Level or Full Rescue)
- Added the ability to activate the Auto Level with or without positive pitch increment also with another unused radio channel
- Added “Use Rescue” checkbox and “Pitch Rescue increment” and “Time Rescue increment” cursors in Advanced -> Setup n° -> Gov. & Level view
- Added the new panel “Rescue” in Advanced -> Common for dedicated radio channel
- Added “Reversed Pitch” checkbox for model in which the maximum pitch is obtained when the swashplate is all down
- Added a bec test during swashplate and tail movements at end of init. If voltage drop more than 12% an event is recorded (only for unit 2)
- Added the ability to write and edit the instructions in any other language other than those already provided and share the language file with other users
- Removed the “Reset Flight counters” from File menu
- Removed the “Main Counters” from Advanced menu
- Added a new Timer menu with the Main Counters and 4 new timers for components maintenances each with a “partial reset” button
- Added Logs Setup views (only for “2” units)
- Added Real time logs view (only for “2” units)
- Added Recorded Logs view (only for “2” units)
- Added Vibration real time view (and recorded only for “2” units)
- Added Events view (only for “2” units)
- Now Setup are in the same page so it is easier to compare
- When you enter a numeric value the box background become yellow until you finish and push “Tab” key
- In panel 2 “Servo Setup” of the wizard, added a Servo chart list (updated with every new release)
- Corrections and fixes to some instructions
- Small bug fixes and optimization of code
Setting changes to do from previous version:
- If you have reversed the pitch in the transmitter, correct it and use "Revesed Pitch" checkbox in panel 6 "Swashplate Type selection" of the wizard, when using reversed swashplate pitch (swashplate down positive pitch)
- Ensure that in the panel 9 "Unit Orientation" of the wizard, the corresponding icon to the actual unit position is active.
Poissa samiwhat
  • TLR-Tiimipelotti
« Vastaus #177 : 07 Kesäkuu, 2016, 22:27:54 »
Tulipa tossa miniä säätäessä tänään torpin jäljiltä päivitettyä tämä uus 2.0 firmis ja muutaman akullisen käväsin testaamassa. Ihan hyvältä vaikuttaa. Ei ainakaan mikään huonompaan suuntaa ole mennyt. Ja tulipa huvikseni testattua tota uutta rescue toimintoakin. Kyllähän se nopeesti flippaa aileronin kautta ja lähtee kohti korkeuksia kun nykäsee kytkimestä, ei siinä, vamaan ihan toimiva juttu, mutta ainakaan mun on turha yrittää opetella tämmösiä, kun se holdi on niin selkäytiymessä.   :) Tossa kokeilin tota muutaman kerran ja sitte vähän tahalleen tein semmosta tosi nopeeta piroflipfloppia korkella, ja suunitelmissa oli nykästä siitä rescue  niin kyllä se holdi heti vaan napsahti, kun pikkasen orientaatio katos.  :D
Poissa Wilikki
  • TLR-Tiimipelotti
« Vastaus #178 : 07 Kesäkuu, 2016, 22:57:03 »
 :D
Minä en kans ymmärrä miten voi olla holdilla vaihtoehto :D
Simussa kerran kokeilin ja totesin pelottava :D
Poissa virtakuono
« Vastaus #179 : 08 Kesäkuu, 2016, 00:19:38 »
Mie taas yleensä kerkeen nykästä holdin samalla sekunnilla kun tömähtää...
Spektrum DX9 black edition
Poissa samiwhat
  • TLR-Tiimipelotti
« Vastaus #180 : 08 Syyskuu, 2016, 21:09:32 »
Pientä päivitystä pukkaa brainiin.
Ja mukana jeti integraatiota !!
 Firmware 2.0.025, Windows Software 2.0.025, Android app 2.0.025 and JETI integration
As usual Software and Firmware update will be automatic and system will prompt user to update once powered unit is connected to a Windows PC with internet connection active. The same for the Android app from Play Store.
Release Notes:
- 2.0.025 (Firmware 2.0.025)
- Jeti EX Bus receiver protocol added with specific channel assignation
- Jeti Connection schematics added
- Jeti transmitter integration with Brain parameters configuration menu (only Brain2)
- Added swashplate HR3_135
- On the top bar added 4 icons for the fast selection between Basic, Advanced, Counters, Diagnostic
- Added Tail gear ratio in Governor (basic & advanced)
- In the vibrations panel added vertical bars for Main Rotor, Tail Rotor, Engine actual RPM
- In the vibrations panel added actual values of Main Rotor and Engine
- Changed event "Power Voltage below 12,5% than startup" to "Power Voltage below 16,6% than startup"
- Now real time vibrations work also on Atom PC and slow PC
- Now when a log is loaded from the unit also the vibrations are downloaded and vice versa
- Corrected for iKon the connection schematic for SUM/SRXL/UDI/Xbus-b
- In the page 1 of the wizard added also the kind of unit connected information
- When Rescue is active, Rescue Gain is fixed and no more editable
- In the Transmitter monitor (basic & advanced) the label "Gain" was changed to "Tail Gain"
- When one of the logs is downloaded from the unit, remain in memory until the end of the session. Changing logs is no more needed to download again the precedent log
- Now AUX channel for Auto Level/Rescue is again usable with standard receiver
- Events downloadable also without sample rate selected (pay attention to download only after the initialization end)
- In the Firmware update windows added on top bar the actual Firmware version of the unit
- In Advanced -> Servos if you select for Type "None" the check is removed from "Reverse"
- “Rescue pitch max” and “Rescue pitch duration” are enabled only if "Use Rescue" is checked
- "Auto Level gain" is enabled only if "Use Auto Level" is checked
- In panel 6 "Swashplate type selection" of the Wizard if "CW ROTOR ROTATION" is selected, the Tail Asymmetry is set to +5, if "CCW ROTOR ROTATION" is selected the Asymmetry is set at -5.
- Maximum gear ratio allowed values for Main and Tail is now 32.500
- In Advanced -> Common re-added the "Orientation" menu but now with only one drop down menu with the 16 allowed positions
- Now when the application start, the windows is at full screen
- New French translations
- Some instructions corrected / completed
For Jeti integration, from “http://www.msheli.com/en/MSHeli-Protos-Flybarless-System/downloads" download the BRAIN.ZIP file and unzip it, it contains an explanation README file and a BRAIN.bin file to load in to the Jeti transmitter.
« Vastaus #181 : 08 Syyskuu, 2016, 23:36:16 »
Toi jeti softa on siis vain brain2:lle.. Ei tule vanhoihin.
Reskue ja live vibra analyysi tuli jokuaika sitten vanhoihinki purkkeihin
1809 Lukukerrat
Uusin viesti 19 Maaliskuu, 2012, 17:30:45
kirjoittanut Terotiutiu
20 Vastauksia
9930 Lukukerrat
Uusin viesti 24 Toukokuu, 2012, 20:46:51
kirjoittanut Trnquill
20 Vastauksia
8936 Lukukerrat
Uusin viesti 14 Lokakuu, 2012, 00:20:08
kirjoittanut Naamis
66 Vastauksia
37388 Lukukerrat
Uusin viesti 12 Heinäkuu, 2013, 23:54:54
kirjoittanut Jussi.
32 Vastauksia
8385 Lukukerrat
Uusin viesti 05 Lokakuu, 2014, 15:52:43
kirjoittanut Korppi
