Kirjoittaja Aihe: Rapu 50, Hentta  (Luettu 12468 kertaa)
Vs: Rapu 50, Hentta
« Vastaus #25 : 02 Kesäkuu, 2008, 21:52:23 »
OK, discussed with Joni today. I think we have a pretty good explanation:
Possibly the pin connecting the tail shaft with the tail pulley came loose. This would explain why it struck like lightning from a blue sky, and why the tail end is completely torn apart.
You live and learn... next time more force and more loctite (+prayer :))
Poissa Silli
  • VLK, KELKO, Loviisan ilmailijat
    • Galleria
Vs: Rapu 50, Hentta
« Vastaus #26 : 03 Kesäkuu, 2008, 00:53:15 »
Sorry to say but you dont get far with those methods.Instead you shoud do as I have adviced on past at lennokit.net`s topic.
You will find it here http://lennokit.net/showthread.php?t=28308...sorry only finnish but perhaps you get it.
Just grind my friend as you have seen done to stabilizer bar at factory.(Drilling a spot to axle for srew head will do also)Forget all other methods  ;) BTW..This conserns all scraptor`s with this type tail.(30-90 Size)
Cheers
Silli
P.S Look closely the other half of tail assembly and you see why I had to find a better solution for this structure.Max 1 gallon more and tail has been in two peaces.
« Viimeksi muokattu: 03 Kesäkuu, 2008, 00:59:49 kirjoittanut Silli »
Vs: Rapu 50, Hentta
« Vastaus #27 : 03 Kesäkuu, 2008, 10:20:27 »
OK, thanks... I ordered the quickUK tail shaft and pulley instead. http://www.quickuk.eu/cat/thunder_tiger_parts/raptor_30_50_parts.html?cat=13&pagesize=40&nav=2
Anyway I'll probably buy a dremel tool to grind notches.
Vs: Rapu 50, Hentta
« Vastaus #28 : 04 Kesäkuu, 2008, 20:51:06 »
Palatakseni vielä tähän kierrosjuttuun. Mukavat kierrokset nupissa alla olevassa quotessa (2400 :o). Kopterina Raptor 50 Titan. Kaveri on kai TT:n kuskeja (Dino Spadaccini)
full flight
This is the full flight you will see me land and needle the motor lean a few clicks, the motor sounds cleaner and pulled allot harder for me
The vid quality is not that great but just listens to that motor go
Setup
TT 53 mp5
Titan 50 metal head
620 sab 2400 on the head
13* pitch and 7 on the cyclic
Vs: Rapu 50, Hentta
« Vastaus #29 : 04 Kesäkuu, 2008, 21:21:04 »
Sen takia se varmaan ajaakin niin rauhallisesti  ;D. Ettei tule boomstrikejä.
Vs: Rapu 50, Hentta
« Vastaus #30 : 04 Kesäkuu, 2008, 23:55:14 »
Ja vielä 620 SABit, 2cm pidemmät ja tunkeutuvat näin ollen peräputken reviirille aikaisemmin... Mielenkiintoinen juttu, mistähän johtu...
Vs: Rapu 50, Hentta
« Vastaus #31 : 13 Kesäkuu, 2008, 22:50:59 »
Raptor flies again, limiter works.
Not sure if it was the needle mod or the breaking-in, but now the TT 50 also works on a cooler plug (OS #8). Have to try 30 % nitro, could use some more power...
JHypp
Vs: Rapu 50, Hentta
« Vastaus #32 : 13 Kesäkuu, 2008, 23:39:48 »
Nice to hear, what limiter you use? RevMax? With OS there is no need to use 30% nitro, you get same power with 20%, I don't know how it is with TT 50, maybe it likes more nitro ;). With RevMax you get feeling like you have more power with same fuel.
-Jari
Vs: Rapu 50, Hentta
« Vastaus #33 : 14 Kesäkuu, 2008, 00:02:58 »
Yes, Revmax. I'll have to try tomorrow again, with a flat 100 throttle curve.
It's now set up for 1800 RPM, but it already bogs when I go into loops etc. Oh well, maybe I'll have to get the OS engine. Or learn to fly less heavy-handed.
4232 Lukukerrat
Uusin viesti 17 Kesäkuu, 2008, 15:06:10
kirjoittanut mnentwig
2228 Lukukerrat
Uusin viesti 25 Heinäkuu, 2008, 11:21:29
4999 Lukukerrat
Uusin viesti 26 Kesäkuu, 2009, 21:26:36
2086 Lukukerrat
Uusin viesti 03 Huhtikuu, 2010, 00:54:24
kirjoittanut JCA
3195 Lukukerrat
Uusin viesti 25 Syyskuu, 2012, 15:19:01
kirjoittanut eriks
