Kyllä raportoidaan kun vaan maailmalta nuo puomit ynm kotiutuu. Setup on mulla vielä hakusessa, olisi huvittanut laittaa Hobbywing Skywalker quadro 20a*4, mutta taitaa tuo 20A esc jäädä pieneksi. Tässä olisi malliksi TBS discon setuppeja joista taidan valita jonkin.
RCTimer A2830-14 750KV 185W outrunner motor with prop adapter - replacement bearings
Note: Same as the TBS 750KV motors, just rebranded
Suggested setup: Gaui 500X 10-inch set, Hobby King F-30A 30A ESC SimonK flashed, Nano-tech 4S 2200mAh, OpenPilot CC
Team BlackSheep branded version available
Tiger Motors MT2216-11 210W brushless motor
Note: Same as the TBS 900KV motors, just rebranded
Tiger Motors MT-2216-10 900KV 210W brushless motor
Suggested setup: Graupner 10x5-inch, DJI 30A Opto, 3s 3300mAh, DJI NAZA
NTM 28-30A 750KV 140W prop drive series motor
Suggested setup: Gaui 500X 10-inch set, Turnigy Plush 25A ESC SimonK flashed, Nano-tech 4S 1800mAh [22] [23]
Suggested setup: Graupner E-Prop 10x5 set, Nano-tech 4S 3300mAh, 1420g with GoPro, 14 min flight time [24]
NTM 28-26A 1200KV 250W prop drive series motor
Note: Some reports of problems with SimonK ESCs [25] [26] [27] WiiESC fix
Suggested setup: APC 8x3.8 propellers, Turnigy Plush 30A ESC, Nano-tech 4S 3300mAh, OpenPilot CC [28]
Suggested setup: APC 10x4.5 propellers, Hobby King F-30A 30A ESC SimonK flashed [29]
Suggested setup: APC 10x4.75 propellers, Hobby King F-30A 30A ESC SimonK flashed, 4S battery [30]
DJI 2212 920KV 144W brushless motor [31] - similar/rebrand of EMAX 2212-3S 920KV [32]
Suggested setup: Gaui 8-inch set, DJI OPTO 30A ESC [33]
Suggested setup: Graupner E-Prop 10x5 set, DJI NAZA controller [34]
Suppo 2810/12 1000KV 225W brushless motor
Suggested setup: Graupner E-Prop 10x5 set, DJI OPTO 30A ESCs, DJI NAZA controller [35]
Suppo 2814/8 1000KV 380W brushless motor
Suggested setup: Graupner E-Prop 9x5 set, DJI OPTO 30A ESCs, 4S 3000mAh+1800mAh, DJI NAZA controller [36]
Tiger MT-4006-13 740KV motor - no punch, vibration free
Suggested setup: 11-inch propellers, DJI NAZA controller, 4S battery [37] [38] [39]
Graupner Compact 300 740KV 9.6V - expensive
Suggested setup: Graupner ESC 18-SC, DJI NAZA controller, Nano-tech 4S 3300mAh [40]
SunnySky Angel A2212 2212-980KV 180W brushless motor
Suggested setup: Graupner 9x5 propellers, 4S 3300mAh, OpenPilot CopterControl [41]
BP Hobbies A2217-9 950KV 200W brushless outrunner motor
Suggested setup: 10-inch propellers, Aeroquad controller, TowerPro 18A ESC, 4S 5000mAh [42]
Potential other candidates:
TorxPower MC2216 Pro 900KV 210W brushless motor [43]
NTM 28-26 1350KV 310W prop drive series motor [44]
NX-4008 620KV Brushless quadcopter motor [45] [46]
Note: Some reports of problems with SimonK ESCs [47]
FM-4008 620KV Brushless quadcopter motor [48]
Avroto M2814-11S Short Shaft 770KV 350W Brushless motor [49]
Tiger T-Motor MT2216-12 800KV 180W brushless motor [50]
Tiger T-Motor MS2212 980KV 165W brussless motor [51]
