Kirjoittaja Aihe: FBL controller  (Luettu 5039 kertaa)
Poissa eriks
  • SIL, RAKU, ESPOO
FBL controller
« : 21 Maaliskuu, 2013, 17:04:54 »
Hi!
what FBL controller would you recomend  for 3D beginner... I can fly normal a bit acrobatics but need some support
Erik
SAB Goblin 630, T-REX 450, NAZA-H, Skookum SK-720
Poissa Naamis
  • RC-Kopterit RY #0252
Vs: FBL controller
« Vastaus #1 : 21 Maaliskuu, 2013, 18:46:43 »
Always a matter of opinion, but I recommend Brain.
Quadro jossa FF Controller
Futaba T8FG, Walkera Devo 7
Phoenix
Vs: FBL controller
« Vastaus #2 : 21 Maaliskuu, 2013, 18:57:57 »
BeastX is really easy to set up and works fine.
Poissa TuukkaJK
Vs: FBL controller
« Vastaus #3 : 21 Maaliskuu, 2013, 19:21:30 »
Plus one for the BeastX. Really easy to setup and doesn't need a computer to setup or fine tune.
        - SPEKTRUM DX8 -
Vs: FBL controller
« Vastaus #4 : 23 Maaliskuu, 2013, 18:42:00 »
Boils down to whether you like to do the setup with computer or not.
Computer: MSH Brain, vBar
No Computer: BeastX or CGY750
Personal, possibly skewed opinion:
When it comes to flight characteristics, with Brain you are a bit more connected to heli,  beastX doe's the trick very well also but you feel a bit external. It is a matter of taste. With CGY, there is ton's of things to tweak but it flies also quite well with defaults. I have never flown anything with vBar but track record is obvious, it's good.
« Viimeksi muokattu: 23 Maaliskuu, 2013, 18:47:38 kirjoittanut Jussi. »
Vs: FBL controller
« Vastaus #5 : 23 Maaliskuu, 2013, 19:28:09 »
I think that Align 3gx is posiblle program with computer or whit out. It´s not bad, better than beast-x.
Poissa eriks
  • SIL, RAKU, ESPOO
Vs: FBL controller
« Vastaus #6 : 25 Maaliskuu, 2013, 11:35:57 »
thanks for your posts  8)
any body have experience with iKON Flybarless System iKON1001
they have Auto Level Technology - does it saves from crashes?
Vs: FBL controller
« Vastaus #7 : 25 Maaliskuu, 2013, 11:43:57 »
as far as i know that thing is same as "Brain" only with different brand.
Vs: FBL controller
« Vastaus #8 : 25 Maaliskuu, 2013, 15:33:22 »
And what I have read about it, better hit throttle hold than auto level.
Poissa heikkit
Vs: FBL controller
« Vastaus #9 : 25 Maaliskuu, 2013, 17:05:57 »
That's the old school way. I bet the auto level has potential, but it is still quite experimental & most of us are used to trottle hold.
Brain auto level e.g., does not take care of tail orientation. That is difficult for beginners.
Vs: FBL controller
« Vastaus #10 : 25 Maaliskuu, 2013, 19:46:12 »
Those will be standard in a couple of years for cheap RTF helis, but how is it supposed to work when you have to set it up (and test-fly it) yourself?
Most people can't stay mentally sharp for the whole flight duration. No, it's a skill that needs to be practised, and it takes a long time to learn. With auto-level, you train instead to flick the switch when a black-out is coming.
Dead end, IMHO, can't remember any success stories, only failure (and the only way not to crash is not to fly).
« Viimeksi muokattu: 25 Maaliskuu, 2013, 19:48:13 kirjoittanut mnentwig »
3837 Lukukerrat
Uusin viesti 02 Tammikuu, 2010, 12:05:01
3000 Lukukerrat
Uusin viesti 12 Helmikuu, 2010, 15:40:42
kirjoittanut JCA
6192 Lukukerrat
Uusin viesti 05 Lokakuu, 2012, 00:24:55
kirjoittanut Ves@
3841 Lukukerrat
Uusin viesti 14 Toukokuu, 2013, 18:33:18
kirjoittanut Tepaja
2453 Lukukerrat
Uusin viesti 03 Elokuu, 2013, 00:26:08
kirjoittanut Regu
