Kirjoittaja Aihe: Kontronik Jive 120+ HV or Castle Creations ICE2 HV120  (Luettu 2550 kertaa)
Poissa eriks
  • SIL, RAKU, ESPOO
« : 05 Toukokuu, 2013, 11:15:39 »
Hei!
What is better Kontronik Jive 120+ HV or Castle Creations ICE2 HV120 ?
is the Kontronik  worth that money ?
kiitos
Erik
SAB Goblin 630, T-REX 450, NAZA-H, Skookum SK-720
Vs: Kontronik Jive 120+ HV or Castle Creations ICE2 HV120
« Vastaus #1 : 05 Toukokuu, 2013, 11:50:59 »
Jive has internal BEC, which others are missing and Castle has logging. But max voltage from Jive is just 6 volts, so no HV-servos then. For the price of Jive, I would take instead Yge 120HV K (K=better cooling) and Gryphon Quasar BEC (really BEC doesn't need to be 12S-capable as you can connect it to lower 6S only) or any decent BEC with adjustable voltage.
Castle is much cheaper (190e from freakware) than Yge/Kontronik and it is widely used. Usually works OK, just don't try to run low throttle% (partial load causes ESC to heat due missing active-free wheeling). Internal governor doesn't match with Yge/Kontronik.
Just get some and go flying, summer is short  ;)
2348 Lukukerrat
Uusin viesti 16 Joulukuu, 2008, 13:34:43
kirjoittanut mnentwig
4080 Lukukerrat
Uusin viesti 06 Heinäkuu, 2009, 16:20:47
kirjoittanut SJo1
33 Vastauksia
15820 Lukukerrat
Uusin viesti 29 Joulukuu, 2011, 14:25:34
kirjoittanut Trnquill
89 Vastauksia
40575 Lukukerrat
Uusin viesti 29 Toukokuu, 2014, 01:08:53
kirjoittanut ryder
2750 Lukukerrat
Uusin viesti 10 Maaliskuu, 2013, 09:06:15
kirjoittanut njs
