Kirjoittaja Aihe: Cyclone lavoista kokemuksia?  (Luettu 14249 kertaa)
« : 17 Heinäkuu, 2013, 18:03:53 »
Onkos kukaan hankkinut noita J1S Designs Cyclone lapoja?
Euroopasta ei taida vielä mistään saada näitä.
http://www.cyclone-blades.com/
Amainhobbies.com:sta mainospuhetta:
This is the J1S Designs "Cyclone" 695mm Carbon Fiber Flybarless Main Blade Set. R/C helicopter performance has been compromised by conventional "straight wing", continuous airfoil blade designs. Flybar blades are quick and responsive around center, but are unstable in fast flight and are prone to pitching up. Flybarless blades are stable and smooth at high speeds, but deliver a slow response around center and are more demanding of your electronics. Traditional designs make it impossible for one blade to provide both characteristics, forcing pilots to choose between crisp response around center or smooth high speed tracking in fast flight; blades that try to deliver both aspects are mediocre at best...until now!
Tim Jones has developed a unique, optimized airfoil design that elevates R/C helicopter blade technology to the next level. J1S Designs Cyclone blades feature an aerodynamically optimized "tapered airfoil" that allows the CG point to be configured in a way that provides fast flight stability, without sacrificing response, or "crispness" around center. The tip shape is unique and allows large cyclic inputs even at the highest forward flight speeds, eliminating the "flutter" or sluggishness that is common with heavy flybarless blades that can stress servos and reduce cyclic rates. This also allows the power system to work more efficiently and lets the blades track with one another much better, even under the most extreme combinations of collective and cyclic pitch.
J1S Designs Cyclone blades won’t make you fly like the Beast, but will deliver the confidence, stability, response and efficiency that will make you feel like one.
Vs: Cyclone lavoista kokemuksia?
« Vastaus #1 : 17 Heinäkuu, 2013, 19:44:47 »
Nyt kyllä pisti tuo mainosvideon EDGE:jen olan yli heitto veks silmään.  :D Ei EDGE:t noin paskat kuitenkaan oo. Pientä uhoa Cyclonen puolelta.
Poissa xio
« Vastaus #2 : 17 Heinäkuu, 2013, 21:25:42 »
Heti kun saapi eu alueelta niin näitä hommataan!  8)
« Vastaus #3 : 17 Heinäkuu, 2013, 21:26:42 »
Voisihan näitä testata. Eiköhän ladille tule kohta
Poissa kaardian
« Vastaus #5 : 23 Heinäkuu, 2013, 22:10:18 »
Ite oon nähny Tim Jonesin lentävän tommosilla... oli ihan kelvollisen näköstä meinkinkiä, ja aika kovaa ääntä ne piti... Videoita tais olla tossa Forth Worthin Kopteritapahtuman yhteydessä olevassa säikeessä.
http://www.kopterit.net/index.php/topic,19132.0.html
4198 Lukukerrat
Uusin viesti 07 Elokuu, 2008, 23:52:09
kirjoittanut Ege
3911 Lukukerrat
Uusin viesti 05 Marraskuu, 2009, 01:19:48
kirjoittanut makopa
3178 Lukukerrat
Uusin viesti 09 Tammikuu, 2011, 17:19:04
kirjoittanut Falconi
3283 Lukukerrat
Uusin viesti 12 Maaliskuu, 2013, 21:31:49
kirjoittanut Miika
3090 Lukukerrat
Uusin viesti 07 Maaliskuu, 2017, 22:43:08
