Kirjoittaja Aihe: TRex 450 SE V2: Upgrade palikoita  (Luettu 7226 kertaa)
Poissa Jyri
  • Jyri Laitinen - Valokuvaaja
« : 14 Heinäkuu, 2008, 01:58:44 »
Vastatkaa tähän topikkiin jos haluatte jotakin mielestänne hyödyllistä upgrade palikkaa saada listalle.
SUOSITELTAVAT PÄIVITYKSET
  • Kevlar Belt, Perusteet??, Heliproz, Readyheli
  • Trueblood Head Dampers, V1 Readyheli, V2 Readyheli
  • A steel pinion (I think Hobbylinna has them now on stock). Get the right number of teeth... Readyheli
  • The two-sided tail pitch slider. Less slop. Highly recommended. Hobbylinna
  • Light (sub-6 grams) paddles. When you want to do your first flips and rolls (gives higher roll rate => faster) Helidirect
    Note that one needs to use anaerobic glue or loctite. I found this out the hard way.
  • Heavy duty landing gear if your autorotations suck as badly as mine: Helidirect
    the chrome flakes off, but it doesn't break. There are also other 3rd party landing gears on the market.
  • Decent hex keys. Check the size, though. RC Sabe
  • STK runko, kevyt, tukeva ja halpa. Helidirect
DIY MODS
  • Chinese weight mods, Lisää pitoa perään, lähes ilmaiseksi HeliFreak.com
  • Remove Idler Pulley, Ei enää hihnan katkeiluja, ilmaiseksi HeliFreak.com
Toivottavasti listasta on hyötyä kaikille...
Vs: TRex 450 SE V2: upg palikoita
« Vastaus #1 : 14 Heinäkuu, 2008, 11:02:34 »
trueblood head dampers
V1 http://www.readyheli.com/TREX_450_SE_V1_Head_Dampener_Upgrade_p/dampeners.htm
V2 http://www.readyheli.com/TREX_V2_Head_Dampener_Upgrade_Red_Dampers_by_Tru_p/dampeners2.htm
http://www.readyheli.com/RevCo_Hard_One_0_5M_Long_Shank_Hardened_Pinion_p/ho-1012.htm
The two-sided tail pitch slider (also Hobbylinna). Less slop. Highly recommended. It may require two additional ball link balls, which should be identical (same weight).
http://www.hobbylinna.fi/kauppa/view_product.php?product=ALHS1175
Light (sub-6 grams) paddles when you want to do your first flips and rolls (gives higher roll rate => faster)
http://www.helidirect.com/product_info.php?products_id=4674
http://www.helidirect.com/product_info.php?products_id=1517
http://www.sabe.fi/hobby/index.php?prodid=32905&grpid=3804
I also use the microheli CNC main wheel because I got tired of the wobbling Align wheel. Most of the stuff above is quite cheap. The wheel is expensive, and no "must-have" upgrade.
And maybe Futaba 9257 servo for rudder...
« Viimeksi muokattu: 21 Heinäkuu, 2008, 10:55:18 kirjoittanut mnentwig »
Poissa JiriK
« Vastaus #2 : 14 Heinäkuu, 2008, 13:48:21 »
Jos haluaa vielä lisää vauhtia kääntymiseen, niin Minititanin vihreät stabbarilavat painaa 4,3g/kpl.
Nuo vs. alignin 5.5g stabbarit Minititanissa - ero on (imho) huomattava.
PV0837 on osakoodi. Saben hyllystä löytyi ainakin viime viikolla.. En tosin nettisivulta löytänyt.
  • Moderator
« Vastaus #3 : 14 Heinäkuu, 2008, 13:59:28 »
http://www.helidirect.com/product_info.php?products_id=1094
Markuksen ehdottamat trueblood kumit on hyvä päivitys, ei kulu läheskään yhtä nopeasti kuin alkuperäiset.
Poissa Jyri
« Vastaus #4 : 15 Heinäkuu, 2008, 23:30:52 »
Markusksen ehdottama "The two-sided tail pitch slider" ei ollutkaan ihan suora vaihto SEV2seen, ainakin siinä on hieman erilainen kiinniotys perälapoihin kuin alkuperäisessä? ja hieman rupesi mietityttämään tuo paremmuuskin, oli kuitenkin kauttaaltaan muovinen ja oli hieman välystäkin...
Enempi on ruvennut houkuttamaan nuo Microhelin monet eri vaihtoehdot, kun vaan keksisi mikä olisi heittämällä perään menevä aluvaihtoehto, eli ymmärrän tuon teorian siitä että olisi hyvä olla molemminpuolin työntö tuota tailpitchslideria, kaiken järjen mukaan nahnittaa vähemmän.
« Vastaus #5 : 21 Heinäkuu, 2008, 10:46:47 »
Thanks for pointing this out. I put it into the V2 without any problems, but it requires two identical ball link balls, though (to put on the blade holders). I included this comment in the mail above.
Otherwise I'd recommend it without any doubt. I have MicroHeli CNC tail parts for $80 on my other T-rex, and the Align two-sided slider has considerably less slop.
One can "break in" those tail mechanics - spin up without blades and gently push the rod against the limit. The slider binds against the 90 degree lever, but it's soft plastic and wears out after a couple of seconds. So you get more pitch range. Not necessary, though - this happened by accident. One can see the result in the first and third picture.
« Viimeksi muokattu: 21 Heinäkuu, 2008, 10:56:03 kirjoittanut mnentwig »
Poissa Jyri
Vs: TRex 450 SE V2: Upgrade palikoita
« Vastaus #6 : 25 Elokuu, 2008, 22:37:30 »
Menihän se tuo "The two-sided tail pitch slider" paikalleen ja ei tosian tarvinnut kuin yhden ylimääräisen pallolinkin.
Gorilla Gear paketti (landing gear, paddles, tail blades) tilattu, toivottavasti saapuu joskus ;) kommentteja seuraa jahka saan ne tulille...
Poissa Jyri
« Vastaus #9 : 09 Syyskuu, 2008, 00:13:59 »
Gorilla Gear kokemuksia
Landärit: paljon pehmeämpää ja joustavampaa kuin orkkikset, ei juurikaan haittaa paitsi landäreistä kopterin nostelu vaikeutui, voisi kuvitella että kestävät huomattavasti rajumpaa käsittelyä kuin orkkikset
Stabbarin lavat: Laitoin ne ilman painoja tulille enkä huomannut minun leijuttelulla/kevyellä lentelyllä eroa orkkiksiin ilman painoja, el ieivät liene mitenkään yliherkät (vaikka itse Finless ajaa niillä siten että sillä on lyhennetyt painot niissä??)
Pyrstöroottorin lavat: Ei ole tullut vielä tehtyä niillä tarkempaa tuttavuutta Henttaan maaperään, mutta lennossa e nole huomannut mitään eroa, paitsi tietty erottuvuus (Fluor Yellow)
Poissa gekki
« Vastaus #11 : 08 Lokakuu, 2008, 17:22:14 »
Onko kellään kokemusta tollasista:
http://www.realraptors.co.uk/shop/index.php?main_page=product_info&cPath=221_228&products_id=2672
onko mitään oikeeta hyötyä vai tuoko vain ulkonäköä.
  • Moderator
« Vastaus #12 : 08 Lokakuu, 2008, 17:30:59 »
Itellä oli tuollaset ennen, lähinnä parantavat ulkonäköä koska nuo on painavammat kuin alkuperäiset -> rollrate hidastui aika paljon. Suosittelen halvempia muovisia. Alignin 3K hiilarikuvioiset muovipaddlet on tosi hyvät.
Poissa gekki
« Vastaus #13 : 08 Lokakuu, 2008, 18:48:25 »
ok. tuota katselinkin että toi alumiininen holkki joka tuossa on saatais painaa enempi kun alkuperänen muovilapa. Jää siis ostamatta.
3374 Lukukerrat
Uusin viesti 07 Maaliskuu, 2010, 16:45:48
kirjoittanut Picofly
3606 Lukukerrat
Uusin viesti 21 Syyskuu, 2010, 21:09:36
kirjoittanut zxiicci
52 Vastauksia
42533 Lukukerrat
Uusin viesti 20 Helmikuu, 2011, 20:32:58
1730 Lukukerrat
Uusin viesti 02 Marraskuu, 2011, 20:50:34
4028 Lukukerrat
Uusin viesti 07 Elokuu, 2012, 00:40:05
kirjoittanut WB
