Kirjoittaja Aihe: Autorotaation suoritus?  (Luettu 13734 kertaa)
Vs: Autorotaation suoritus?
« Vastaus #25 : 04 Heinäkuu, 2009, 20:07:03 »
Vanha topic...
also check that throttle hold uses the full pitch range of the head. Depending on the setup, this can make a dramatic difference.
For example:
My 450 uses 5..95 % pitch curve in all flight modes, and 0..100 in throttle hold. 5 % difference isn't much.
On the 700, on the other hand, I fly with 16..84 %. Autos with that get quite awkward (been there done that forgot to use throttle hold when the ESC shut down).
Poissa ropellihattu
« Vastaus #26 : 04 Heinäkuu, 2009, 20:34:44 »
"also check that throttle hold uses the full pitch range of the head. Depending on the setup, this can make a dramatic difference."
On this one I have to disagree. Unless there is a severe front wind you do not need all the negative that you can get. I noticed, that when my max neg pitch is 9 deg, I only lower the throttle stick about a half down measured from the center point of the stick. This is about -5, maybe -6 degrees. As explained in the "kopteriopas", too much negative kills the inertia pretty efectively...
On the other hand, of course, it´s all the same if your hold pitch range reaches all the way down. You still don´t have to pull the stick all the way down, but this makes the smooth auto more difficult to perform.
Nada
« Vastaus #27 : 04 Heinäkuu, 2009, 21:20:05 »
right, and that's not what I meant. Full negative in emergencies maybe, otherwise around -5 or so. No, full positive pitch, for the last meter.
Poissa ropellihattu
« Vastaus #28 : 04 Heinäkuu, 2009, 21:22:15 »
Yeah, ok, I also don´t know what you meant. But anyhow, frontwind, dare to try...
Nada
« Vastaus #29 : 04 Heinäkuu, 2009, 21:28:16 »
simple ...
with +13 your skids will say "thank you"
with only +8 they will say "thsnk you SIR may I have another"
 ;D
Poissa ropellihattu
« Vastaus #30 : 04 Heinäkuu, 2009, 21:36:08 »
Oh, you´re quoting animal house.
But yes, you´re absolutely right. And have made more auto´s than me, so... :P
Nada
22 Vastauksia
11439 Lukukerrat
Uusin viesti 20 Tammikuu, 2010, 18:55:27
17 Vastauksia
8226 Lukukerrat
Uusin viesti 24 Tammikuu, 2010, 21:27:06
kirjoittanut fosa
