Kirjoittaja Aihe: Raptor 50 pinion  (Luettu 3596 kertaa)
Raptor 50 pinion
« : 30 Heinäkuu, 2008, 14:31:19 »
Any idea what happened to this pinion??
There is 1/2 mm of metal missing (where the hex key points to). The bearing sits tight in the frame - I changed it anyway.
Total flight time maybe 8 gallons.
« Viimeksi muokattu: 30 Heinäkuu, 2008, 14:53:37 kirjoittanut mnentwig »
JHypp
Vs: Raptor 50 pinion
« Vastaus #1 : 30 Heinäkuu, 2008, 16:50:56 »
There bearing in frame just in that place, it is better to check that too ;). By the way, put green or red loctite to that place. I thing you have heard some noise, when you start your Raptor, because of that "missing metal" between pinion and bearing ::)
-Jari
« Vastaus #2 : 30 Heinäkuu, 2008, 17:32:03 »
Thanks, that sounds like a good idea. Will do.
Yes, it is worn out under the bearing. I have read that in some cases the whiole bearing has too much space inside the frame and moves, but mine was tight.
Funny noises, yes, I noticed when it comes to a stop.
4626 Lukukerrat
Uusin viesti 28 Toukokuu, 2007, 16:45:49
kirjoittanut Marcus
2385 Lukukerrat
Uusin viesti 04 Maaliskuu, 2009, 09:43:45
1821 Lukukerrat
Uusin viesti 05 Huhtikuu, 2011, 19:24:53
kirjoittanut Illodin
4267 Lukukerrat
Uusin viesti 03 Elokuu, 2016, 07:40:24
kirjoittanut Hayabusa
9801 Lukukerrat
Uusin viesti 30 Tammikuu, 2017, 16:58:28
kirjoittanut 338federal
