Näyttää kyllä ihan kivalta, kun noita vbarejakin on useita niin sais kätevästi luettua kaiken datan ja säädöt tehtyä tuosta mankasta. Toi model sharekin näyttää aika mielenkiintoselta ominaisuudelta
http://shop.mikado-heli.de/VBar-Control.htm?shop=k_mikado_e&SessionId=&a=catalog&t=7560&c=7560&p=7560Software Highlights:-Set up, programming and adjusting of VBar-controlled model helicopters accomplished directly via VBar Control transmitter.
-No computer, control panel or smartphone necessary.
-Instant access to almost every flight parameter from the transmitter controls, even in flight.
-Easy programming for new helicopters via the familiar VBar setup wizard.
-New ESC setup wizard for programming all types of speed controllers.
-Bank switching with three banks.
-Real time logging and real time vibration analysis readable from the transmitter.
-Several telemetry functions are available, such as voltages, current, rpm, speed, and power consumption of the batteries (may need aditional hardware).
-Storage of event log files like VBar event log, VBar Control event log, GPS way points, voltage/current logging etc.
-Multiple timer functions available with warnings and reminders via sound, voice, or vibration output.
-Wireless buddy boxing with two VBar Control transmitters, fully configurable.
-Easy bind process, allows bind and fly of any model equipped with VBar Control (e.g. a buddy‘s heli) with your own transmitter (Model Sharing).
-Software updates via internet using a simple VBar Control Manager app and the web browser.
-Option for adding new features via apps, simple installation via internet, supports both Windows and Mac OS X-PCs, no drivers needed.
-Additional airplane software will be available in summer 2014.
Hardware Highlights:-80 Channel 2.4 GHz FHSS bidirectional flight control, programming/setup and telemetry remote control system.
-VBar Control Satellite Receiver connects directly to VBar flybarless controller via 2.4GHz VBar-Link protocol.
-Unlimited model memory.
-Virtually unlimited number of control channels.
-High range, low latency, antenna diversity on both transmitter and receiver.
-Intelligent antenna monitoring and management.
-XXtra Bright Graphic Display featuring high contrast and ambient light sensor to automatically control the display brightness, making it equally well readable in bright sunlight and in the dark.
-Easy Dialog System with rotary dial for convenient and safe inputs, with optical, tactile and acoustic feedback.
-Precision gimbals with four ball bearings, fully adjustable.
-Collective stick equipped with optional throw limiter.
-Fully equipped with four 3-position-switches, two quick-break-switches and two rotation knobs, all fully programmable.
-Delicate rubber lining for comfortable, slip-free and safe holding.
-3-point neck-strap attachment, for optimum balance.
-Large 2 Watt loudspeaker for alarms and voice output.
-Vibration alarm (adjustable).
-Internal 8 MB flash memory.
-Memory accessible as a USB memory stick, no drivers needed.
-4.000 mAh Lithium Polymer battery allows for long run times.
-Charge through USB connector or built-in charger.
-Power Supply for fast charging included.
