Kirjoittaja Aihe: Mikado V-Bar Control Radio  (Luettu 119116 kertaa)
« : 20 Helmikuu, 2014, 12:00:11 »
Mikadolta on tulossa uusi mankka, täähän vois olla vaikka seuraava radio :)
« Viimeksi muokattu: 17 Marraskuu, 2015, 00:02:00 kirjoittanut Tohtori R »
Vs: Mikado V-Bar radio
« Vastaus #1 : 20 Helmikuu, 2014, 12:20:23 »
Näyttää kyllä ihan kivalta, kun noita vbarejakin on useita niin sais kätevästi luettua kaiken datan ja säädöt tehtyä tuosta mankasta. Toi model sharekin näyttää aika mielenkiintoselta ominaisuudelta :P
http://shop.mikado-heli.de/VBar-Control.htm?shop=k_mikado_e&SessionId=&a=catalog&t=7560&c=7560&p=7560
Software Highlights:
-Set up, programming and adjusting of VBar-controlled model helicopters accomplished directly via VBar Control transmitter.
-No computer, control panel or smartphone necessary.
-Instant access to almost every flight parameter from the transmitter controls, even in flight.
-Easy programming for new helicopters via the familiar VBar setup wizard.
-New ESC setup wizard for programming all types of speed controllers.
-Bank switching with three banks.
-Real time logging and real time vibration analysis readable from the transmitter.
-Several telemetry functions are available, such as voltages, current, rpm, speed, and power consumption of the batteries (may need aditional hardware).
-Storage of event log files like VBar event log, VBar Control event log, GPS way points, voltage/current logging etc.
-Multiple timer functions available with warnings and reminders via sound, voice, or vibration output.
-Wireless buddy boxing with two VBar Control transmitters, fully configurable.
-Easy bind process, allows bind and fly of any model equipped with VBar Control (e.g. a buddy‘s heli) with your own transmitter (Model Sharing).
-Software updates via internet using a simple VBar Control Manager app and the web browser.
-Option for adding new features via apps, simple installation via internet, supports both Windows and Mac OS X-PCs, no drivers needed.
-Additional airplane software will be available in summer 2014.
Hardware Highlights:
-80 Channel 2.4 GHz FHSS bidirectional flight control, programming/setup and telemetry remote control system.
-VBar Control Satellite Receiver connects directly to VBar flybarless controller via 2.4GHz VBar-Link protocol.
-Unlimited model memory.
-Virtually unlimited number of control channels.
-High range, low latency, antenna diversity on both transmitter and receiver.
-Intelligent antenna monitoring and management.
-XXtra Bright Graphic Display featuring high contrast and ambient light sensor to automatically control the display brightness, making it equally well readable in bright sunlight and in the dark.
-Easy Dialog System with rotary dial for convenient and safe inputs, with optical, tactile and acoustic feedback.
-Precision gimbals with four ball bearings, fully adjustable.
-Collective stick equipped with optional throw limiter.
-Fully equipped with four 3-position-switches, two quick-break-switches and two rotation knobs, all fully programmable.
-Delicate rubber lining for comfortable, slip-free and safe holding.
-3-point neck-strap attachment, for optimum balance.
-Large 2 Watt loudspeaker for alarms and voice output.
-Vibration alarm (adjustable).
-Internal 8 MB flash memory.
-Memory accessible as a USB memory stick, no drivers needed.
-4.000 mAh Lithium Polymer battery allows for long run times.
-Charge through USB connector or built-in charger.
-Power Supply for fast charging included.
« Vastaus #2 : 20 Helmikuu, 2014, 12:48:23 »
On kyllä hyvin mielenkiintoinen!
Pääsee säätään kaiken suoraan radiosta vaikka kesken lennon, ominaisuus joka helpottais kopun säätämistä halutuks.
Toivottavasti hinnoittelevat ton sellaiseksi että on vielä järkevää ostaa.
Olisko eka mankka joka on suoraan suuniteltu koptereille? Vaikka näköjään tulossa lentskareille kans oma softa 2014.
« Vastaus #3 : 20 Helmikuu, 2014, 13:27:17 »
Periaatteessa hyvä juttu, mutta vielä en tiedä oikein miten suhtautua. Spektrumin satelliiteilla on nykyään jo mukavan kompakti setuppi. Lisäksi säätöjen hiominen lennossa on alun jälkeen hyvin pientä. Itsellä itseasiassa heitin Logo 550SX:ään tehdas säädöt eikä vielä muutoksia ole tarvinnut.
Etuja joita itse keksin vs DX8:
- Vibra näyttö suoraan mankalle.
     * Ongelmatilanteissa hyvä ja jos kopteri lentää lähes optimaalisesti mutta vibrat pilaa käytöstä.
- Several telemetry functions are available, such as voltages, current, rpm, speed, and power consumption of the batteries (may need aditional hardware)
      * Telemetriat löytyy Spektrumilta, joten josko tähän nyt saisi sen kulutetut mAhit suoraan.
Muita etuja en sitten oikein keksi. Spektrum on varmaan käärmeissään että Mikado tulee heidän tontilleen. Vähän myöskin pelottaa se että kuinka paljon Mikadolla on varaa satsata tähän sivujuonteeseen. Kuinka usein tulee uutta rautaa tms.
Hyvä kuitenkin että tulee kilpailua enemmän.Kyllähän tätä voisi harkita kun itselläkin kaikissa koptereissa on VBar.
« Vastaus #4 : 20 Helmikuu, 2014, 14:13:33 »
Onhan tosta lennonaikaisesta säätämisestä kuitenkin etua, voit vaikka lisätä/laskea nuppiin kierroksia oman maun mukaan ja agility, yaw rate, paddle simulation, style jne. asetuksia muokata niin ettei tartte läppäriä alkaa käynnisteleen.
Se että 550SX oli kertalaakista säädöissä ei ole mikään ihme, koska kyseessä on tehtaan oma tuote ja valmiit arvot löytyy suoraan :) Mutta noita edellämainittuja säätöjä ei kukaan voi valmiiksi kertoa, koska on aika henkilökohtaisia mieltymyksiä.
Telemetria näyttäis olevan paljon monipuolisempi kuin Spektrumissa ja paljon yksinkertaisempi kun ei tule mitään lisäpalikoita.
Joten plussat siitä.
Uskon kyllä että Mikadolla on paukkuja laittaa tälläiseen kehitystyöhön, ovat ainakin tähänmennessä tehneet kaikki tuotteensa paremmin kuin Horizon Hobby
« Vastaus #5 : 20 Helmikuu, 2014, 16:25:16 »
Onhan tossa noita toimintoja MUTTA!
Eikö ketään tosiaan kiinnosta lähetystekniset jutut. Toimintoja on kiva olla mutta niillä ei tee mitään jos yhteys pätkii ja kopterit torppaantuu...
En tarkota että tää olis jotenki huono. Eihän sitä vielä kukaan tiedä. Mä tarkotan sitä ettei kannata sokeesti kattoa että tossa olis hienoja juttuja toi otetaan. Kannattaa varmaan odotella että lähettimen/vastareiden luotettavuus tulee ilmi. Se on kuitenkin paljon tärkeämpää ku mitkään toiminnot.
Fbl kopterihan säädetään kerran ja sitte se on tehty eikä sitä tartte uudestaan säätää. ;)
« Vastaus #6 : 20 Helmikuu, 2014, 16:53:16 »
Tohtori, tuollahan mainitaan lähetystekniikka, onko toi sitten huono? Eli lähdetkö olettamuksesta if $(Mikado radio != futte) then return "CRAP" ;D
Tottakai tuo kiinnostaa, tuo vastari on aikamoinen jööti, toimintojakin on jo kaksisuuntaisuudenkin taki jonninverran. En nyt lähtis heti torppaamaan, kahtotaan mitä maailmalla tapahtuu.
Eikä noilla mankoilla o pian paskankaan väliä kun saa lennättää 100km asutuksesta keskipäivällä kaks tuntia alle 10 metrissä...
« Vastaus #7 : 20 Helmikuu, 2014, 17:45:27 »
enhän mäkään tota torpannu. tarkotus oli ilmasta että ei kannata olla sokea hienojen toimintojen edessä.
lähettimen tärkein ominaisuus on kuitenkin luotettavuus.
eli kannattaa odotella sen aikaa että se havaitaan maailmalla hyväksi tai huonoksi ja vasta sitte tehdä ostopäätös.
protokollat voi olla mitä vaan mutta laitteissa voi olla heikkoja kohtia ja suunnittelun kukkasia.
itse ostaisin lähettimen joka on todettu pommin varmaksi. täähän voi ihan hyvin ollakkin semmonen. sitä ei vaan vielä tiedä.
« Vastaus #8 : 20 Helmikuu, 2014, 18:29:17 »
Meinaatko että olen sokaistunut hienoista ideoista?  ;)
Kyllähän sen nyt kaikki tietää että luotettavuus on tärkeä asia ja uskon että Mikado on saattanu sellaisiakin juttuja varmaan ehkä miettiä?
Ekana en olis kyllä tätä ostamassa ja lähitulevaisuus kyllä kertoo että sataako kopuja taivaalta tällä vehkeellä.
« Vastaus #9 : 20 Helmikuu, 2014, 18:35:02 »
en tarkottanu ketään yksilöä vaan ihan yleisesti.
ihan hienolta kyllä näyttää. toivottavasti on hyvä värkki.
« Vastaus #10 : 20 Helmikuu, 2014, 18:54:43 »
tästä lisään vielä kun tuli mieleen. Spektrum on myös iso merkki ja myy paljon radioita. mä en nyt hauku tässä spektrumia vaan koitan kertoa hyvän esimerkin siitä mitä mä tarkotan.
speku tosiaan myy paljon ja onhan noitakin testattu varmaan ihan tuhottomasti ennen myyntiin laittamista. silti kun speku lanseeras uuden lähetysprotokollan joka oli DSM-X pääs lähettimien firmikseen sellanen lapsus että tiettyjen DSM-2 vastarityyppien kanssa yhteys pätkii pitkiäkin aikoja. toi ei ollu tullu niissä niiden testeissä ilmi ja tuote tuli myyntiin.
no eräs Tohtori R osti sitte sellasen DX8 mankan mutta sillä oli 500rekkulassansa vanhan mallinen DSM-2 vastari joka siis piti toimia ja toimikin kunnes ei enää toiminu ja kone tiedottomana kivikkoon ja 300e korjauskuluja.
Speku sitte huomas myöhemmin ongelman ja kutsu laitteet takasin tehtaalle sisäisen lähetinmodulin firmiksen vaihtoon joka on siis eri asia ku ite mankan firmis. sitä ei voinu tehä ku spekun huollossa.
ne luetteli ne muutamat vastarityypit minkä kanssa ongelma on havaittu. mun vastari oli yks niistä. tää ongelma käsitti kaikki spektrumin radiot mitkä tukee DSM-X protokollaa.
tämmösiä ihme epätodennäkösyyksiä mä tarkotan. kannattaa tosiaan hetki ventata ennenku rupee ostamaan ihan uutta radiomerkkiä. hyvähän tosta varmaan tulee sen verran kovat nimet takana. hyviähän noi spekutkin kai nykyään on jossain määrin.
« Viimeksi muokattu: 20 Helmikuu, 2014, 18:56:40 kirjoittanut Tohtori R »
« Vastaus #11 : 20 Helmikuu, 2014, 18:57:47 »
Jos on hyvät ominaisuudet ja luotettava niin onko se hinta suurikaan kriteeri. Paitsi tietysti jos ei ole rahaa. ;)
« Vastaus #12 : 20 Helmikuu, 2014, 19:14:48 »
Hmm...
Ekan erän koput kyllä kelpa, mutta mankan kanssa ollaan kriittisiä.
Jr ja Jeti on tuota fhss alkaneet puskea eteenpäin ja futtellakin tuota on tarjolla. Joten fhss ilmeisesti protokollana ihan ok.
Jr on jopa Androidin ottanut käyttöön, mutta Futte on käyttänyt M$ win ce:tä tuossa mz14 &18 mankoissa.
Ehkä tuo vbar mankka toimii tai sitten ei, aika näyttää...
Edelleen kuolaan tuota Jeti DS16 mankkaa...
« Viimeksi muokattu: 20 Helmikuu, 2014, 19:19:26 kirjoittanut SJo1 »
« Vastaus #13 : 20 Helmikuu, 2014, 19:19:05 »
Hmm...
koput on mekaniikkaa.
FHSS on futtella se halppis protokolla noissa J-sarjan "budjettiradioissa". kirjain yhdistelmät voi olla samoja mutta ne voi eri merkeillä toimia ihan erilailla.
« Vastaus #14 : 20 Helmikuu, 2014, 19:21:50 »
Niin tuo fhss on myös tuossa 14SG mankassa fast, fastest lisäksi;)
« Vastaus #15 : 20 Helmikuu, 2014, 19:24:13 »
niin on. siinä on ne kaikki. kaiken maailman pikku puistovehkeet kuten trex150 käyttää tota fhss protokollaa.
mutta tää nyt ei liity tohon veepaar mankkaan ei sitte millään lailla. siinä on vaan sama kirjainyhdistelmä
« Vastaus #16 : 27 Helmikuu, 2014, 11:43:13 »
Tuleeks jollain muullaki mieleen vähä halvan näkönen radio? Tossa vilahtelee tuota materiaalia ja muutenkin mekaanista jälkeä, ei oikein vakuuta?
(Sivukommenttina: Kylläpä kaveri lentelee ahtaassa....)
« Vastaus #17 : 27 Helmikuu, 2014, 11:55:21 »
Tuli jo heti ekasta videosta vähä huono laatuvaikutelma noin niinku visuaalisesti. Omaan silmään ei vaan toi look sovi. Harmaata paukkumuovia. Paukkumuoviahan nää kaikki futtet, spekut sun muutkin on vaikka jotku muovikromia jäljitteleekin :D
Tärkeinhän on kuitenki se miltä gimbaalit tuntuu ja miten ne on laakeroitu. Jää nähtäväksi.
Toi käyttörulla vaikuttaa hyvältä. Ei mitään hiplausjuttuja vaan kunnon mekaaninen rulla. Mun mielipide on että noi hiplauskäkkänät on vaan turhaa hifistelyä vailla tarkotusta ja ainakin 8fgs kohdalla se vaan vaikeuttaa asioita.
Toi näyttö ja käyttis näyttää hienolta :)
« Vastaus #18 : 27 Helmikuu, 2014, 12:04:55 »
Just noin, toi antaa aika kaks-jakosen fiiliksen. Paljon hyvää, hyvä idis mun mielestä toi "kaikki muisti v-barissa" eli ohjain on pelkkä ohjain eikä enää se tietokone.
Ja ton rulla-jutun allekirjoitan täysin, mä en voi sietää tommosia kosketusrullahärpäkkeitä joilla vielä on kaks toimintoa joka nurkassa. Ne on saatanasta ja pitäis hukuttaa jokeen ;D
Toivotaan että jossain pääsee joskus hipelöimään.
« Vastaus #19 : 27 Helmikuu, 2014, 12:10:41 »
Toi tosiaan näyttää aika karulle, mutta toisaalta se ei vaikuta lentämiseen.
Vaikuttaa näppärälle toi kopun vaihto toiseen, eli virrat pois ja toiseen kopuun virrat päälle ja sit lentämään.
Ei tartte mitään model muisteja valkkailla.
« Vastaus #20 : 27 Helmikuu, 2014, 12:47:31 »
On tossa joo uusia pikkujuttuja jotka todella miellyttää. Hiplaamasn vaan pitäis päästä.
Yks mikä kiinnostaa on että mitä uutta toi vaadittava uus v-bar firmis tarjoaa meille normikäyttäjille. (Jos mitään)
« Vastaus #21 : 27 Helmikuu, 2014, 13:21:20 »
Ruman näköistä muovia, ainakin väriltään.  Voisko olla vielä joku prototyyppi, joka on tehty kopunetin 3D tulostajien avustuksella? Muuten tosiaan aika mielenkiintoinen.
« Vastaus #22 : 27 Helmikuu, 2014, 15:32:37 »
onhan se kyllä kova homma vaihtaa malli raatiosta :D
« Vastaus #23 : 27 Helmikuu, 2014, 15:35:08 »
Eiks toi ominaisuus ole jo Futabassa? :)
« Vastaus #24 : 27 Helmikuu, 2014, 16:07:15 »
Joo, futaballa voit lentää samalla ohjelmalla kaikkia kopujas, mutta mites on niiden säätöjen kanssa?
En usko että onnistuis niin että lennättäisit samalla ohjelmalla sun G500:sta ja HV7:aa?
Ja toi mallin vaihtaminen ei tosiaankaan ole mikään kova homma, mutta jos multa kysytään että haluatko aina näprätä mankkaa kun kopu vaihtuu, vai lähdetkö vain lennättään niin vastaus on aika helppo antaa ;)
28 Vastauksia
39537 Lukukerrat
Uusin viesti 14 Huhtikuu, 2008, 13:50:09
kirjoittanut Ville Erkkilä
3872 Lukukerrat
Uusin viesti 14 Huhtikuu, 2012, 16:25:03
kirjoittanut mnentwig
4731 Lukukerrat
Uusin viesti 26 Marraskuu, 2015, 23:49:54
33 Vastauksia
10688 Lukukerrat
Uusin viesti 14 Syyskuu, 2018, 09:58:17
kirjoittanut Mesihukka
1122 Lukukerrat
Uusin viesti 23 Marraskuu, 2022, 10:02:12
