Kirjoittaja Aihe: hobbywing noparit  (Luettu 3911 kertaa)
Poissa HeliFlyFinland
  • Moderator
hobbywing noparit
« : 07 Kesäkuu, 2015, 07:58:01 »
Hobbywing  ohjelmointi kortti
Multifunction LCD Program Box
1 Working Modes
1.1 Works as an individual device to set the ESC, the value of each parameter is displayed on the LCD screen.
1.2 Works as an USB adapter to link the ESC with a PC to update the firmware of the ESC or set the ESC by HOBBYWING USB LINK SOFTWARE .
1.3 Works as a Lipo battery voltmeter to measure the voltage of the whole battery pack or each cell.
2 Specifications
2.1 Size: 90mm (L) * 51mm (W) * 17mm (H)
2.2 Weight: 65g
2.3 Input Voltage: 4.5-12.6V
(If the ESC hasn’t a built-in BEC, you must use an additional battery pack to supply the program box)
2.4 Displayer: 16*2 characters LCD.
2.5 Interface: Mini USB interface, ESC interface (Futaba plug), Power supply interface (Futaba plug)
3 Compared with the "2 in 1 Professional LCD Program Box"
Models of LCD program boxes:
2 in 1 Professional LCD program box (Already stopped)
Multifunction LCD program box: It is a new priduct uses MCU (microprocessor) with larger memory, it has a new function to work as Lipo battery voltmeter to measure the voltage of the whole battery pack and each cell.
Firmware for the LCD program boxes:
2 in 1 Professional LCD program box:
It has 2 types of firmware
a) Type A: The firmware with postfix “_V3” (eg. V1.11_120331_V3) is only suitable for XERUN-120A-SD V3 and V3.1 ESC
b) Type B: Firmware without postfix “_V3” (eg. V1.08_120504) is suitable for the ESC below except the XERUN-120A-SD V3 or V3.1 ESC.
i. XERUN series V2.0 and V2.1 car ESCs;
ii. EZRUN series V2.0 car ESCs;
iii. Platinum series aircraft/helicopter ESCs.
iiii. Platinum V3 series aircraft/helicopter ESCs.
Please select the correct firmware for the 2 in 1 professional LCD program box according to the type of the ESC. The factory-preset firmware is Type B, but it can be upgraded to Type A and downgraded to Type B by user himself.
Because of its larger memery size, a single firmware can be compatible with all speed controllers, including XERUN series V2.0/2.1/3.0/3.1, EZRUN V2.0, Platinum series and Platinum V3 series.
This Multifunction LCD Program Box is suitable for the following ESC:
XERUN & EZRUN series Car ESC (Version 2.0 and 2.1)
XERUN-120A V3 & V3.1 ESC
PLATINUM series helicopter/aircraft ESC
PLATINUM V3 series helicopter/aircraft ESC
A) The programmable items for the XERUN and EZRUN series car ESC:
1 Running Mode
2 Drag Brake Force
3 Low Voltage Cut-Off Threshold
4 Start Mode
5 Maximum Brake Force
6 Maximum Reverse Force
7 Initial Brake Force
8 Throttle Neutral Range
9 Timing
10 Over-Heat Protection
11 Motor Rotation
12 Lipo Cells Amount
*Note: Some speed controllers have less programmable items, but some have more. Please read the user manual of your speed controller to get detail information.
B) The programmable items for the PLATINUM series airplane ESC:
1 Brake
2 Battery Type
3 Low Voltage Protection Mode (Cutoff Mode)
4 Low Voltage Protection Threshold (Cutoff Threshold)
5 Start Mode
6 Timing
7 Governor Mode
8 Reserved Item #1
9 PWM Frequency
10 Built-In BEC Output
11 Reserved Item #2
C) The programmable items for the PLATINUM V3 series airplane ESC:
1 Brake
2 Battery Type
5 Flight Mode
6 Autorotation Restart Time
7 Timing
8 PWM Frequency
9 Built-In BEC Output
10 Lipo Cells Amount
  • Moderator
Vs: hobbywing noparit
« Vastaus #1 : 07 Kesäkuu, 2015, 08:00:50 »
Säädin
Features
1.1 High-performance microprocessor with the operating frequency up to 50MHz brings excellent compatibility (with most motors in the market) and high driving efficiency.
1.2 The maximum motor speed can reach 210000 RPM (for 2-poles), 70000 RPM (for 6-poles) and 35000 RPM (for 12-poles).
1.3 Multiple flight modes: Fixed Wing Airplane/ Heli with Governor Off/ Heli with Governor (Elf) / Heli with Governor Store.
1.4 Adjustable throttle range, compatible with various transmitters. It brings smooth, soft & linear speed adjustment and rapid throttle response.
1.5 Microprocessor powered by independent DC regulator has better anti-interference performance, which greatly reduces the risk of losing control.
1.6 Built-in high-efficient & high-power (switch mode) BEC can make the output voltage switched among 5.2V / 6.0V / 7.4V / 8.4V. (*For the specific output voltage, please refer to the parameter list below.)
1.7 Brand new governor program, easy to operate; and its excellent speed-governing effect can make big rotor blades more stable even under rapid load change.
1.8 ”Restart in auto rotation" can manually interrupt the auto rotation and quickly restart the motor to avoid crashes caused by incorrect operations.
1.9 Independent output port for RPM (that is: motor speed) signals.
1.10 Compatible LCD program box (*optional accessory), its simple and visual interface allows users to set/revise all the ESC parameters easily. (For detailed information, please refer to User Manual of LCD Program Box.)
1.11 Upgradeable firmware, you can upgrade the ESC after connected it to a PC via the USB cable on the program box.
1.12 The independent port, for connecting the program box and setting parameters, can also be the output port of the running status data of the ESC. When coordinating with the data transmission module, it can make the real-time data monitoring and logging possible.
1.13 Multiple protection features including input voltage abnormality protection/ low-voltage cutoff protection/ throttle signal loss protection effectively prolong the service life of the ESC.
TECHNICAL DATA
2-6S Lipo, 5.2V-25.2V
100A
BEC: , 6.0V/7.4V/8.4V
Cont.: 10A
Burst: 25A
70x35x21mm
104g
FOR GOBLIN 380
  • Moderator
« Vastaus #2 : 07 Kesäkuu, 2015, 08:06:40 »
Hinnat:
Hobbywing 100A nopari 98 €
Ohjelmointikortti  39 €
Näitä saadaan vain 10 kpl ,
suuren kysynnätakia tehdas ei pysty toimittamaan isoja määriä, tuotteet lähtee meille tiistaina
samassa kuormassa tulee moottorit
« Vastaus #3 : 07 Kesäkuu, 2015, 09:08:59 »
Mulla on kaksi kpl noita käytössä.
Toinen on 100A nopari 500L:ssä. Tässä on käytössä noparin oma govi. Noparin astuksista on muutettu ainostaan Heli gov store päälle ja bec jännite => 7,8v. Hyvin pelaa ja olen tyytyväinen.
Toinen on kiinni 450L:ssä. Tämä on helimodessa ja govinan on vbar:n govi.
Tämäkin pelaa hienosti.
Molemmissa saisin varmaankin lisää tehoa ajoitusta muuttamalla. Mutta en ole vielä tarvinnut sitä.
Ohjelmoinnit olen tehnyt piippamalla, minusta ohjelmointi onnistuu näin helposti.
Kortilla vielä hempommin.
ps. Tossa 100 noparissa tuli puhallinkin mukana. En ole käyttänyt kun tarvetta ei ole.
Poissa Otou
  • #102, Sil
« Vastaus #4 : 17 Elokuu, 2015, 19:19:46 »
Goblin 380 toimii moitteettomasti myös 50A versiolla. Mosana xnova tareq edition. Saa ihan kunnolla kyykyttää mut hyvin pelaa  8)
2285 Lukukerrat
Uusin viesti 10 Marraskuu, 2010, 20:18:39
kirjoittanut jkaija
27 Vastauksia
20425 Lukukerrat
Uusin viesti 28 Helmikuu, 2014, 19:56:48
kirjoittanut Ves@
7076 Lukukerrat
Uusin viesti 05 Joulukuu, 2015, 17:27:01
kirjoittanut Kallo
7047 Lukukerrat
Uusin viesti 09 Lokakuu, 2015, 22:23:38
kirjoittanut privy
57 Vastauksia
42661 Lukukerrat
Uusin viesti 23 Tammikuu, 2017, 22:11:09
kirjoittanut Konna
