Nyt saatavilla myös
Huippu voitelu liukupinnoille, linkkeihin ja rattaisiin
DryFluid Extreme Rc-Heli 10 ml 14,40€
DryFluid Extreme Gear lube 10 ml 14,50€
DryFluid Heli
DRYFLUID HELI HIGH END SLIDE- LUBRICANT FOR LINKS, SHAFTS AND BEARINGS
BALSAM FOR RC HELICOPTERS
DryFluid Extreme was specially developed for radio controlled model helicopters with the aim to preserve as long as possible or rather to extend significantly the efficiency and lifetime of these mechanical marvels. The effect of this new slide-lubricant for links, shafts and bearings begins where others show their limits. Lowest sliding friction, maximum speed and minimal dust and dirt binding were the main objectives of the development. Findings in the aviation and vehicle industries and the expert knowledge of RC Heli pilots are the driving forces behind this new lubricant.
SLIDE-LUBRICANT INSTEAD OF OIL
DryFLuid is a dry slide-lubricant rather than a classic oil or grease. DryFluid is not wax, it is neither greasy nor oily but is silicone-free. A long-lasting lubrication effect is achieved using dry particles, sliding polymers and high end sliding fluids. The application and long-term effects of DryFluid Extreme will interest every RC pilot.
PRODUCT-FEATURES
Reduction of power loss on links, shafts and bearings and it guarantees a long life of the treated componentsLowest sliding friction for free movement and wear reductionMultistage lubricant system with immediate and long-term effectsDust and dirt repellentExtremely good creeping abilitiesExcellent material compatibility with all current metal, plastic and natural rubber materialsOutstanding adhesive and anti-corrosive properties
See for yourself the amazing effect of using DryFluid Extreme Heli.
High End slide-lubricant for links, shafts and bearings of RC
helicopters. It contains top-class lubricating components from the aviation and vehicle industry. Extremely low friction coefficient. Excellent long-term lubrication results.
