Kirjoittaja Aihe: Brain 2  (Luettu 25700 kertaa)
Poissa samiwhat
Brain 2
« : 14 Toukokuu, 2016, 10:38:57 »
Uutta versiota pukkaa brainistä. Eta kolme viikkoa. Tuli vähän yllätyksenä että sieltä tulee kummiskin uutta rautaa. Tähän asti on vaan puhuttu softa päivityksistä
http://www.helifreak.com/showthread.php?t=744600
When we started work on Brain2 almost 1 1/2 years ago, we kept asking ourselves, what makes a system truly great? For something to earn "legendary" status, it of course comes from the guys using it, and truly loving it. So then the goal is to make a system indispensable. Something intangibly great. Something that exceeds the sum of its parts.
The flybarless system is the heart of the helicopter. It connects to every major component. It's our interface and view into how we connect with our machines. So then we set out to focus on the idea of making Brain2 the ultimate toolbox with a single minded goal of getting the most enjoyment possible out of the machine with the least amount of guessing and frustration.
You guys have seen the work we've done with Rescue. An incredibly complex piece of software in order to make the end user experience a trivial and great one. The new rescue works on Brain1 as a free update and of course Brain2 has it.
But Brain2 has much more. Here's a few highlights of what's new. As we get closer to release, more information will be available.
5 new Brain hardware platforms. From small to heavy duty. With some surprising integration
Faster CPU with hardware acceleration features
Full high resolution logging capability using an on board non-volatile memory. Brain2 takes logging to the next level in an incredibly useful and meaningful way
Event logging for high level review of every flight making it easy to diagnose issues
Full vibration logging on 3 discrete axis, and complete playback of vibration levels from flights
Real time vibration and logging support (view events as they happen)
All new rescue feature (also supported on Brain1)
We are still committed to Brain1 development, as can be seen with the free rescue update coming soon. We are also working on things like support for Jeti which will come with firmware updates in the near future. Brain1 also gets real time vibration analysis.
ETA is about 3 weeks.
Vs: Brain 2
« Vastaus #1 : 14 Toukokuu, 2016, 11:38:11 »
Ylättävää ja erityisen positiivista   että tekevät silti vanhaan noinkin suuria päivityksiä!
Vs: Brain 2
« Vastaus #2 : 25 Toukokuu, 2016, 09:27:28 »
Ennakkotilaukset käynnissä: http://shop.msheli.it/Category.aspx?ID=21
Esittely: http://www.msheli.com/en/MSHeli-Protos-Flybarless-System/brain-2-flybarless
Osassa mm. sisäänrakennettu bluetooth.
Vs: Brain 2
« Vastaus #3 : 17 Kesäkuu, 2016, 20:04:11 »
Tyhmä kymysys. Käykö tähän sama ykkös version Android säätö softa?
Kuitenki kohta halvalla näitä kitin mukana tulleita myynnissä, kun porukka vaihtaa Kbar Neon tilalle :D
Poissa samiwhat
Vs: Brain 2
« Vastaus #4 : 17 Kesäkuu, 2016, 20:10:56 »
Käy
Vs: Brain 2
« Vastaus #5 : 17 Kesäkuu, 2016, 20:37:47 »
OokoO👍
Poissa R3DgRu
Vs: Brain 2
« Vastaus #6 : 26 Syyskuu, 2016, 21:46:40 »
Miten saan brainin tallentamaan logiinsa moottorin kierrosluvun vai saanko mitenkään?
Minulla on siis Hobbywing Platinum Pro V3 100A -nopeudensäädin, Xnova XTS 3215 930 Kv -moottori, tämä Brain 2 gyro, ja Hitec Maxima 9 -vastaanotin ja Aurora 9X -radio.
Nopeudensäätimen oranssi johto, joka on rpm singaalijohto, on kytketty brainin  gov-porttiin. Vastaanotin kun on erillinen, niin kaasu on kytketty sinne ja näin ollen vastaanotin hoitaa kaasukanavan ohjauksen suoraan ilman että brain on välissä. Käytössä on noparin governööri.
Kuvassa on siis kytkentapa. Tuon lisäksi rpm johdon olen laittanut kiinni gov -porttiin, mutta kierroslukemat näyttää vielä logissa nollaa.
« Viimeksi muokattu: 26 Syyskuu, 2016, 21:48:30 kirjoittanut R3DgRu »
SAB Goblin Raw | SAB Goblin 380 | FrSky Taranis QX7S | Phoenix RC
Poissa Konna
Vs: Brain 2
« Vastaus #7 : 27 Syyskuu, 2016, 06:02:25 »
Oletko kokeillut signaalijohtoa molemminpäin?
Mikado Vbar Control Touch
Poissa R3DgRu
Vs: Brain 2
« Vastaus #8 : 27 Syyskuu, 2016, 09:16:13 »
En ole, se on nyt niinpäin, että se johto menee ylinpään niistä kolmesta pinnistä koska se on singaali ja alemmat on plus ja miinus jännite. Voin kokeilla tänään toisinkin päin jahka pääsen kotia.
Poissa samiwhat
Vs: Brain 2
« Vastaus #9 : 27 Syyskuu, 2016, 09:48:51 »
Oliko siellä logeissa vaihtoehto että voi rpm tiedon logittaa? Mun mielestä ei ollut, mutta voin iltasella tarkistaa asian. Kytkentä kuulostaaa ihan oikealta eli rpm singnaali keltainen johdin siihen brainin signaalituloon.
Poissa Bnito
Vs: Brain 2
« Vastaus #10 : 27 Syyskuu, 2016, 11:01:45 »
Kyl sielä rpm logitus on. Itellä ainakin tulee tiedot logille kun se on valittuna.
Poissa R3DgRu
Vs: Brain 2
« Vastaus #11 : 27 Syyskuu, 2016, 19:49:37 »
Tiedä häntä mikä tuota vaivaa. Nollasin tänään brainin ja asensin uudestaan, mutta ei vaikutusta.
Oletko Bnito säätänyt mitä kaikkea siitä asetusohjelman governor-välilehdeltä? Laitoin itse välitykset mutta muuhun en koskenut, koska luulisi sen riittävän. Brainin logi tosiaan mittaa nupin kierroksia moottorin sijaan, joten siihen tarvitsee tietysti niitä välityssuhteita.
Poissa Bnito
Vs: Brain 2
« Vastaus #12 : 27 Syyskuu, 2016, 21:32:28 »
onko sulla sensing divisor laitettu oikein (motin puolat jaettuna 2:lla )? ja onko alhaalla magnet detected täppä ?
Poissa R3DgRu
Vs: Brain 2
« Vastaus #13 : 27 Syyskuu, 2016, 21:35:51 »
Tuo sensing divisor on oikein, mutta tuosta magnet detected hommaa en muista, pitääpäs tarkastaa huomenna.
Poissa Bnito
Vs: Brain 2
« Vastaus #14 : 27 Syyskuu, 2016, 21:47:09 »
Brainin gov setupis muuten lukee et Note : this function does not work with separate receiver setup due to the throttle connection to the receiver instead the unit.
Poissa R3DgRu
Vs: Brain 2
« Vastaus #15 : 28 Syyskuu, 2016, 10:17:15 »
Jep, en vain halua govia edes käyttöön vaan pelkästään kierroslukemat. Voi tietysti olla että sekään ei onnistu, mutta saa nähdä.
Vs: Brain 2
« Vastaus #16 : 28 Syyskuu, 2016, 10:50:33 »
No eiks se govi ny melkein samalla vaivalla kannattas sit viritellä? Ei siitä mitään haittaa ole, päinvastoin.
Poissa Bnito
Vs: Brain 2
« Vastaus #17 : 28 Syyskuu, 2016, 12:12:56 »
Mutta kun sitä govia ei saa jos on erillinen vastari minne menee throttle kanava. Eli jos throttle kanava ei tule suoraan brainiin ei govia saa käyttöön. Ainakin niin luki tuossa brainissa jonka pari viestiä sitten englanniksi laitoin...
Poissa samiwhat
Vs: Brain 2
« Vastaus #18 : 28 Syyskuu, 2016, 12:36:53 »
Otat sen throtle johdon vastarista irti ja laitat brainiin?
Vai oliko joku syy että throtle pitää olla vastarissa suoraan?
« Viimeksi muokattu: 28 Syyskuu, 2016, 12:39:20 kirjoittanut samiwhat »
Poissa Bnito
Vs: Brain 2
« Vastaus #19 : 28 Syyskuu, 2016, 12:49:28 »
Ei kyl mielestäni voi toimia jos mankalta ei tule throttle kanavan tietoa. Tx -》rx -》brain. Ja vedät kaasu kanavan poikki tx ja rx välistä niin milläs ohjaat kaasua?
Poissa samiwhat
Vs: Brain 2
« Vastaus #20 : 28 Syyskuu, 2016, 13:06:12 »
Mikä mankka/vastari sulla on?
Poissa Bnito
Vs: Brain 2
« Vastaus #21 : 28 Syyskuu, 2016, 13:32:53 »
Ylipäätään silti tuntuu oudolta jos tuo brain ei erillis tx kytkennällä tue govia ja varsinkaan et rpm ei näkyis logille jos rpm signaali kuitenkin tulee suoraan brainiin vaik th kanava ei tuu...
Poissa samiwhat
Vs: Brain 2
« Vastaus #22 : 28 Syyskuu, 2016, 14:27:35 »
Jaahans hupsista minä jo elin maailmassa jossa jo kaikki vastarit jo kytketään fbl purkkeihin jollain väyläprotokalla. Meni vähän ohi tuo kun kännykällä tihrustin tätä säiettä.
No eihän se braini voi govina toimia jos kaasu ei mene sen kautta. Govihan ohjaa kaasukanavaa. Tuosta rpm logituksesta en osaa sanoa kun en ole sitä tutkinut.
Poissa R3DgRu
Vs: Brain 2
« Vastaus #23 : 28 Syyskuu, 2016, 15:39:27 »
Tuo ettei govia saa toimimaan ei ole mikään uusi juttu, tiesin sen kyllä. Haluaisin vain nähdä kierrosluvun koska mielestäni noparin govi ei toimi kunnolla vaan kopteri tuntuu aika "joustavalta" jos antaa lapakulmia nopeasti. Haluaisin vain varmistaa tämän, että onko vika missä jos sitä edes on. Olen vain täysi aloittelija, joten en osaa sanoa miten kopterin pitäisi liikkua kuin youtuben perusteella.
Vs: Brain 2
« Vastaus #24 : 28 Syyskuu, 2016, 19:20:47 »
No tuolla mosalla se liikkuu vähintäänkin riittävästi. Veikkaan että vika on joku/jotkut seuraavissa:
- Noparin kaasun end pointit opetettu väärin (ainakin HW 130 Tarvitsee)
- Collective kulmaa ei ole tarpeeksi 13-14 astetta voisi olla kovasana
- Moottori pulley liian pieni-> ei jää goville head roomia
- Akut kypsät, eikä anna virtaa
181 Vastauksia
97303 Lukukerrat
Uusin viesti 08 Syyskuu, 2016, 23:36:16
kirjoittanut jkkmobile
20 Vastauksia
8953 Lukukerrat
Uusin viesti 14 Lokakuu, 2012, 00:20:08
kirjoittanut Naamis
66 Vastauksia
37516 Lukukerrat
Uusin viesti 12 Heinäkuu, 2013, 23:54:54
kirjoittanut Jussi.
2458 Lukukerrat
Uusin viesti 03 Elokuu, 2013, 00:26:08
kirjoittanut Regu
1905 Lukukerrat
Uusin viesti 15 Helmikuu, 2015, 13:24:39
kirjoittanut Picea
