Uutta päivitystä tullut brainiin.
Release notes:
- 3.0.020 (firmware 3.0.020)
• Now in Advanced->Common->Receiver, 3 different transmitter dial channels are each associable to one of 47 different parameters to be able to increase and/or decrease parameter value during flight
- Added under "MANUALS", the "Analogic_integration_by_ transmitter_potentiomete r s.pdf"
- In Advanced in each screen, data are updated at a faster speed
- In Advanced->Setup, the title of the actual active Setup, highlight
- In Advanced->Common->CCPM, the cursors of Pitch Mixer, Aileron Mixer and Elevator Mixer now have graphic full throw
- Minimum value for Cyclic Gains in panel 13 of the Wizard reduced from 10 to 7 (for tri-blades that have low gains)
- Totally re-writhed the CCPM 135 FW and SW. Now changing Servo Angles in Advanced->Common->CCPM, things change (before Servo Angles does nothing) and reversed CCPM 135 now work with the indicated servo position on the swashplate design/icon (changed name and icon all from 140° to 135° as is ever been the value of this setup)
- Now Check Mode activate also if a Castle Creation ESC is connected but not powered.
• Added the loggable variable "ESC LS RMP (CC max 2500)" for user that don't use Brain Governor and don't have any RPM sensor connected to the Brain. LS mean a Low speed rate compared to a fast hardware RPM sensor
• With Spektrum telemetry, now is transmitted the "Receiver voltage" to the "Flight Log" screen when the receiver don't transmit this info (like SPM4649T receiver)
• For Jeti Integration released a new brain.bin v1.4 file that must be saved in the device folder of the transmitter overwriting the precedent version
• Jeti Integration, added under “Other”, graphic Vibration analysis
• Jeti Integration, added under "Blade Size Preset", two / three blades selection and updated the Elevator D gains
• Jeti Integration, added under "Common Parameters", “Calibration Dial” menu
• Jeti Integration, added under “Other->Counters”, the possibility of reset the four counters
• Jeti Integration, revised some names ("Main Battery mA used" to "Main Battery mAh used", "FramerateTX" to "RxFramerate")
• Jeti Integration, added "Scorpion" to the list of ESC telemetry
- Fixed the problem for which is needed a complete deinstallation and reinstallation of the Windows Software when firmware size grow to a new limit
- Revised the software compatibility with the very old OS "Windows XP"
- Added links to Analogic_integration_by_ transmitter_potentiomete rs .pdf instruction also in the Windows Menu->Program folder
- Under MANUALS, new version of "README_for_Jeti_integrat ion_with_BRAIN.pdf" instruction
- Under MANUALS, new version of "ESC_datas_log_telemetry. pdf" instruction
- English instructions and balloons revised, updated, corrected, completed
- French instructions and balloons revised, updated, corrected, completed
- Russian instructions and balloons revised, updated, corrected, completed
- Interface improvements
- Small bug fixes and optimization/compression/reduction/speed up of the code
Android app will be released tomorrow morning.
iOS app is in review from Apple, and we hope Apple release during next week.
_____________
