Kirjoittaja Aihe: iCharger X6  (Luettu 2907 kertaa)
iCharger X6
« : 09 Heinäkuu, 2018, 21:26:17 »
Junsilta tullut uusi laturi WoH:lle myyntiin: http://www.world-of-heli.de/antrieb-elektro/ladegeraete/junsi/junsi-icharger-x6-ladegeraet-800w---6s.html
Hinta 129€
Junsi iCharger X6 Charger 800W to 6S Lipo
Compact microprocessor controlled high-performance fast charger / discharger and balancer with 2A balancer current per cell
The Junsi X6 provides up to 800W charging power (from 23.5V)
1-6s LiPo cells and up to 30A charging current are also sufficient for large, high-capacity batteries.
Of course, all other battery types such as LiHV, LiIo, NiZn, PB, NiCd or NiMh batteries can be charged.
The discharge capacity is 30 watts, but can be increased up to 900W by means of an external load (discharge resistor).
Of course, the iCharger X6 also masters regenerative charging. Here, the battery capacity is fed back, for example, from a full flight battery in the supply battery.
The balance current of 2 amps always ensures perfectly balanced cell voltages.
The 2.4 "IPS LCD display ensures perfect readability
Micro SD Card Slot is also integrated and can be used to log data & store loader programs
Also firmware update via the USB port are possible.
More functions:
Internal resistance measurement of the cells
integrated servo tester
Technical specifications:
Microprocessor controlled high-performance fast loader / unloader and balancer
2.4 "IPS LCD Color Display - 320x240
Supported battery types: LiIo / LiPo / LiFe / LIHV / LTO / NiZn, NiMH / NiCd, Pb
Number of cells: 1-6 LiIo / LiPo / LiFe / LIHV / LTO / NiZn, 1-16 NiMH / NiCd, 1-12 Pb (2-24V)
Input voltage: DC 7-32V
Input current: <35A
Charging power max .: 800W from approx. 23.5V input voltage
Charging power at input voltage 12V:> 400W
Charging current: 0.05 - 30A
Discharge capacity max .: 30W
Discharge current: 0.05 - 30A
Regenerative discharge: up to 800W
Unloading with external load max .: 900W 30V / 30A
Balancer current: 2A per cell
automatic fan control - 1 fan
Micro USB port
Micro SD slot for storing logs and data
Dimensions: 83 × 64.5 × 37 ± 0.5mm
Weight: 168g
Delivery:
Junsi iCharger X6
1x output cable 3.3 mm˛ with XT60 socket
1x input cable 3.3 mm˛ with XT60 socket
Installation CD with software and instructions in English
temperature sensor
printed german manual
Vs: iCharger X6
« Vastaus #1 : 10 Heinäkuu, 2018, 19:08:58 »
Päällepäin kyllä selkeetä yhdennäköisyyttä isdt bg 8s:n kanssa. Minkähänlainen käyttöliittymä täs X6:ssa on, ei oikein kuvasta käy ilmi?
Vs: iCharger X6
« Vastaus #2 : 10 Heinäkuu, 2018, 20:21:20 »
Tuollainen kuva on ainakin WoH:n sivuilla.
Vs: iCharger X6
« Vastaus #3 : 10 Heinäkuu, 2018, 20:27:30 »
Ei ne ainakaa mitää uutta o tehny...
Vs: iCharger X6
« Vastaus #4 : 10 Heinäkuu, 2018, 21:36:41 »
Ku olis kaikki liittimet samalla kyljellä niin olis hyvä. Vaan ei
3349 Lukukerrat
kirjoittanut IL
10391 Lukukerrat
kirjoittanut Spin
3052 Lukukerrat
kirjoittanut JCA
3326 Lukukerrat
kirjoittanut Dumle
288 Vastauksia
119641 Lukukerrat
Uusin viesti 11 Tammikuu, 2017, 20:47:51
