Kirjoittaja Aihe: Aerofly Professional - Mac OS X versio  (Luettu 4550 kertaa)
« : 26 Huhtikuu, 2009, 11:00:20 »
No niin, Mäkkikäyttäjien riemuksi Ikarus on julkaissut Aerofly'sta natiivin Mac OS X version  8)
IKAFPDIVMAC : Aerofly Professional Deluxe PLATINUM EDITION with USB Interface (for MAC)
AFPD with Interface, AddOn 1 - 5. The AFPD Platinum Edition is a special edition of probably the most successful RC flight simulator available. Besides the simulator, it contains all 5 AddOns (extension packages).
With Aerofly Professional Deluxe you can fly with highly detailed airplanes and helicopters on your home computer. If you have never flown an RC airplane or helicopter, or are a professional flyer, this radio control Flight Simulator will make you a better pilot.
By flying with an RC transmitter, in a photo-realistic landscape, using planes and helicopters that react exactly like the real ones, your skills and confidence will increase quickly.
You can try out maneuvers that you would be afraid to attempt with your expensive model in real life, then when you have perfected them on the Simulator, you will be amazed at how well you'll perform them with your actual model.
Features:
124 aircraft models: aerobatic airplanes, helicopters, 3D-funflyer, 3m-TOC models, Jets, VTOL-Harrier, Gliders,
Biplanes, Slope-soarer, Shockflyer, Pylon-racer, Slowflyer, multi-blade helicopters, and much more...
50 beautifully designed sceneries (including 36 photo-realistic sceneries)
Dynamic shadow.
Real environment reflection mapping on reflective aircraft parts
Simulation of back-light effect through the sun.
Glider sound.
6 music songs exclusively composed for AeroFly.
Full collision detection with all objects in the scenery, including trees.
Realistic simulation of the airplane sound in 3D, like the doppler effect
Simulation of retractable gears and moving wings
2 player split-screen mode allows you to fly AeroFly with your friends on the same computer.
Recording/Playback and Saving of flights.
Torque-Roll training with many different models, like the Cap232, Giles202, Extra 330, Shockflyer.
Autorotation practice with the helicopter.
Smoke and exhaust effects.
When crashing or in certain flight maneuvers, aircraft parts can break apart.
Simple file format for creating your own sceneries and aircrafts.
Different contests like balloon popping, drag racing, pylon racing or spot landing a 2nd view window.
Available in 5 languages.
MAC-System Requirements
(Please read the recommended System Requirements, before ordering)
·Apple Mac with Intel Prozessor
·Mac OS X Leopard ( 10.5 )
·ATI or NVIDIA compatible 3D-graphics card with 128MB
·1 GB RAM
·DVD drive
Continue Shopping
tuupola
Vs: Aerofly Professional - Mac OS X versio
« Vastaus #1 : 27 Huhtikuu, 2009, 09:51:05 »
Kuinka laadukas tuo simu on? Phoenixia voi kyllä ajaa macilla kunhan on Parallels (tai Bootcamp).
« Vastaus #2 : 27 Huhtikuu, 2009, 10:48:13 »
Simun laadusta en osaa sanoa, kun en ole koskaan edes nähnyt ko simua käytössä.
Linkki oli pakko laittaa kuitenkin, koska he joilla ei ole Parellelsia, VMware Fusionia tai bootcampiä paikallaan (eikä tule) saivat uusia ulottuvuuksia mäkkeihinsä :)
Poissa 0lli
« Vastaus #3 : 27 Huhtikuu, 2009, 10:49:34 »
Ihan hauska sillä on ajella, ainakin Windows-versiolla. Tuntuma on vähän hitaampi ja pehmeämpi kuin Phoenixissä, eli tuntuu hiukkasen helpommalta. Koptereista puuttuu ärhäkkyyttä tai sitten vaan ilma on siinä vähän sitkeämpää. Erona on myös se, että fotorealistisia kenttiä on vain muutama ja loput ovat 3d-malleja, joten kameran saa seuraamaan konetta tai laitettua vaikka koneen nokkaan. Radion saa tuossakin säädettyä toimimaan hyvin.
Voisi tuota kokeilla, mutta en ole ihan varma, toimiiko radio-usb-sovittimeni Macin kanssa.
« Vastaus #4 : 27 Huhtikuu, 2009, 11:03:43 »
Tää platinaversio sisältää noi lisälevyt ja ohjaimen: http://www.modelhelicopters.co.uk/acatalog/FlightSims_FlightSim.html#aIKAFPDGCMAC
Toinen versio sisältää USB sovittimen, eli omalla mankalla ajetaan. Yhteensopivuudesta eri mankkojen kesken en tiedä.
Uudessa versiossa on mukana 36 photorealistista kenttää
« Viimeksi muokattu: 27 Huhtikuu, 2009, 11:06:07 kirjoittanut Sammy »
8056 Lukukerrat
Uusin viesti 30 Toukokuu, 2010, 21:31:21
kirjoittanut jkaija
5242 Lukukerrat
Uusin viesti 01 Heinäkuu, 2014, 23:45:17
kirjoittanut VERTICAL
3372 Lukukerrat
Uusin viesti 15 Tammikuu, 2015, 18:10:27
12636 Lukukerrat
Uusin viesti 23 Helmikuu, 2015, 21:46:26
kirjoittanut Aiv
24 Vastauksia
9453 Lukukerrat
Uusin viesti 10 Joulukuu, 2015, 19:53:52
kirjoittanut xio
