Kirjoittaja Aihe: iCharger 208B  (Luettu 10390 kertaa)
iCharger 208B
« : 18 Huhtikuu, 2010, 09:50:34 »
Moi,
I got a pair of 208B iChargers last week from Sabe.
From my experience thus far, I can wholeheartedly recommend them. As some people may remember, I own quite a collection of chargers. And this is "the" charger.
- the iChargers operate down to below 6 V input voltage. Hyperion stops slightly below 11 V, Bantam around 10. So I can use only a fraction of my car battery's capacity, which is very annoying.
- they can balance charge two 4s packs in series, works very well (but don't mix up the wiring. Or else.).
- they give excellent power output at 12 V input voltage. I think I have observed ~30 V 9 amps (270 watts), and more at a higher input voltage
Balance boards and wires were not included (IC9-11 is Sabe's code for the wire, ICXH the Align-compatible balancer board).
the paint isn't the most resilient one, so you can take off the stupid feature list on the front panel with a pencil eraser :-)
Button response is sometimes a bit sluggish, takes some getting used to. And the input wires are rather short, which makes perfect sense at 24 amps max. to not waste too much power.
« Viimeksi muokattu: 18 Huhtikuu, 2010, 09:59:05 kirjoittanut mnentwig »
Vs: iCharger 208B
« Vastaus #1 : 18 Huhtikuu, 2010, 10:20:56 »
You should not drain your car battery below 11v. For example the CTEK car battery charger does not even start to charge a battery if the voltage is below 10.5V, since it is considered dead for good without no hope for successfull rescue. Usually they can be charged but anyway.
Vs: iCharger 208B
« Vastaus #2 : 18 Huhtikuu, 2010, 11:11:14 »
Pitääpä laittaa eilen räpsäisty kuva osasta Markuksen latauskalustoa.
Vs: iCharger 208B
« Vastaus #3 : 18 Huhtikuu, 2010, 11:35:48 »
it's not that simple there is voltage drop also along the wires. The battery is written off anyway.
If need be, I can always jump-start the car from the 3s pack on my Dynatron.
BTW I have deep-discharged my car battery dozens of times so that the car refused to start. In that sense, I don't care too much what I "should" or "shouldn't" do.
And, the car is a "Ford". There was no hope already the day I bought it  :)
« Viimeksi muokattu: 18 Huhtikuu, 2010, 12:08:21 kirjoittanut mnentwig »
Vs: iCharger 208B
« Vastaus #4 : 18 Huhtikuu, 2010, 12:46:30 »
Mulla on ollu tän laturin kanssa sellainen ongelma, että se ei aina lähde lataamaan akkua vaan juuttuu siihen ruutuun, jossa ilmoittaa monenko kennon lataus on valittu ja montako kennoa akusta on löytynyt. Juuttumisen jälkeen laite boottaa itsensä.
Vekottimeen olisi ilmeisesti tarjolla softapäivitys, jota en ole vielä kokeillut tehdä. Ehkä auttaisi asiaan... muuten loistava laturi!
Poissa Simo_M
Vs: iCharger 208B
« Vastaus #5 : 18 Huhtikuu, 2010, 13:03:30 »
[quote author]
Input voltage range: 4.5 - 32.0VDC
[/quote]
Maksimikäyttöjännite 32V  :) ,tuo on hyvä juttu. Voi käyttää esim. 24V teollisuusvirtalähteitä (halpoja) tai kannettavien tietokoneiden virtalähteitä jotka ovat yleensä 16-18V. Kannettavien virtalähteet eivät anna kovin paljoa virtaa, mutta ovat mukavan pienikokoisia pitää mukana.
Poissa Mikka
  • Jäsen nro #99
Vs: iCharger 208B
« Vastaus #6 : 18 Huhtikuu, 2010, 13:29:33 »
Never had problems with iCharger 1010B+ either, so very satisfied with that. But, the input voltage range of the 208B is the best on the market I guess. Did somebody follow the rcgroups(?) thread about iCharger? Is there any bug fixes or new features added recently (within a year) by Junsi (better not update firmaware unless real reason ie. bug fix or some usefull new feature)?
Poissa floodi
Vs: iCharger 208B
« Vastaus #7 : 18 Huhtikuu, 2010, 19:18:47 »
Mulla teki eilen samaa. Ongelma ratkesi kun laitoin ladattavat akut kiinni vasta sen jälkeen kun itse laturi saa virtaa. Se varmaan haluaa kalibroida jotain ja ei tykkää jos siellä on lipo valmiiksi persiissä kiinni :)
Vs: iCharger 208B
« Vastaus #8 : 18 Huhtikuu, 2010, 19:39:31 »
I updated mine immediately to the latest firmware.
Poissa Mikka
  • Jäsen nro #99
Vs: iCharger 208B
« Vastaus #9 : 18 Huhtikuu, 2010, 19:48:49 »
Kannattaa varmaan kokeilla uusinta softaa ja jos ei toimi, niin raportoida viasta siellä foorumilla (olettaen, että toistettavissa).
Poissa Spin
Vs: iCharger 208B
« Vastaus #10 : 27 Lokakuu, 2010, 15:14:15 »
Ensimmäistä tasaavaa laturia ois hankintalistalla (nykyisin erillinen tasuri vielä) ja ichargereihin olen kallistumassa. Tämä 208b lienee ois sopivin vaihtoehto vaikka vielä ei olekkaan kuin 6s akkuja. Riittäis myös 206b, mutta hintaero varsin pieni.
Pitikin kysymäni, mitä piuhoja paketista löytyy? Tuleeko mitään tasurijohtoja/lautoja valmiina. Erillään saa noita lankkuja tietty, mutta pitääkö ostaa jotain johtoja laturin ja tasurin väliin? Näkyy Hobby J-P:llä olevan "BW-7-11 wire" ja "BW-9-11 wire". Mitäs nuo käytännössä ovat, vai tuleeko noiden tasurilankkujen mukana liitosjohdot.
Kotoa löytyis jo bantamin tasuriin neljänlaista tasuriliitin lankkua max. 6s pakkojen tasaukseen. Onkohan noita mahdollista käyttää tämän laturin kanssa?
Spektrum DX18
PhoenixRC
Vs: iCharger 208B
« Vastaus #11 : 27 Lokakuu, 2010, 19:21:53 »
Jos Hobbykingiltä ostat tuon iCharger 208B+ laturin, niin siinä tuli mukana tasurilauta ja väli kaapeli:)
Otin 2 kpl, kun oli niin halpoja;)
Poissa Spin
Vs: iCharger 208B
« Vastaus #12 : 27 Lokakuu, 2010, 19:37:03 »
Hk:ltä saldot miinuksella. Ja suht pieni hintaero ois tuohon laturi + poweri yhdistelmään.
Spektrum DX18
PhoenixRC
Paikalla Anssi
Vs: iCharger 208B
« Vastaus #13 : 27 Lokakuu, 2010, 19:47:58 »
Kannattaa kysyä Sabesta tarjousta. Siellä varasto plussan puolella...
Lennokkimestari #100,
Poissa Spin
Vs: iCharger 208B
« Vastaus #14 : 27 Lokakuu, 2010, 20:15:31 »
Pitääkin tosiaan kysäistä Sabelta. Hobby J-P:llä näyttäis olevan laturi + poweri alta 160e. Tosin vain 10A poweri, mutta kyllä sitäkin käyttäis vaikka kakkoslaturin powerina ja siirtäis tehokkaamman Ichargerille. Mielestäni tuo Hobbykingin hinta ei tältä osin ole mikään tosi edullinen. Toimitusajatkin kun tahtoo olla paria kolmea viikkoa tilauksesta. Jos vielä huonolla tuurilla menis tulliin, niin hintaeroa ei jäisi juuri ollenkaan.
Spektrum DX18
PhoenixRC
Vs: iCharger 208B
« Vastaus #15 : 28 Lokakuu, 2010, 17:40:27 »
Oman 208B:n kun tilasin niin hinta oli kuninkaalla joku 94 dollaria, niillä oli sellanen että kun kattoo jotain tuotetta pitkään niin ruutuun pomppas tarjous, noi exclusiiviset platinauraani jäsenet saa kans kaiken halvalla..
Poissa Spin
Vs: iCharger 208B
« Vastaus #16 : 28 Lokakuu, 2010, 18:24:31 »
Joo toisinaan tuleekin noita tarjouksia kun pitää vain auki ikkunaa. Ja platinajäsen itsekin. Tilasin nyt kuitenkin taas vaihteeksi Suomesta ja Sabelta laturin. Saa vähän järkevämmällä toimitusajalla. Vois harkita vaikka toisen tilaamista sitten hobbykingiltä kunhan tulee saldoja. Ja jos sais tuon tarjouksen :). Toki myös 206b riittäs toiseksi. Orbitit joutais myydä pois, vaan ei noista taida enää saada mitään rahallista etua, joten josko jättäis kolmos ja neloslatureiksi :).
Niin...uusiutuukohan nuo tarjoukset koskaan samalla koneella istuttaessa tai samoilla tunnuksilla kirjauduttaessa? Ajattelin, että tulevat kuitenkin jokakerta, mutta eipä tunnu tulevan.
« Viimeksi muokattu: 28 Lokakuu, 2010, 18:39:18 kirjoittanut Spin »
Spektrum DX18
PhoenixRC
Vs: iCharger 208B
« Vastaus #17 : 28 Lokakuu, 2010, 19:54:47 »
Uusiutuu... se on hämäys juttuja nuo, muistaakseni tartte ku käydä eri sivulla niin saa taas tarjouksia... oliko vielä niin että tuo tarjous hinta on sama ku kaikille platina jäsenille?
Vs: iCharger 208B
« Vastaus #18 : 28 Lokakuu, 2010, 22:29:23 »
Uusiutuu joo ja on.
Poissa Spin
Vs: iCharger 208B
« Vastaus #19 : 28 Lokakuu, 2010, 22:59:34 »
Uusiutuu joo ja on.
No ilmankos noita ei tule silloin kun on sisäänkirjautunut. Kun kirjautuu ulos niin alkaa tulla tarjouksia :).
Spektrum DX18
PhoenixRC
3348 Lukukerrat
Uusin viesti 08 Maaliskuu, 2009, 19:33:09
kirjoittanut IL
2473 Lukukerrat
Uusin viesti 23 Kesäkuu, 2010, 09:39:16
kirjoittanut Xen
3052 Lukukerrat
Uusin viesti 01 Tammikuu, 2012, 14:35:39
kirjoittanut JCA
3325 Lukukerrat
Uusin viesti 23 Toukokuu, 2012, 14:51:57
kirjoittanut Dumle
18 Vastauksia
8276 Lukukerrat
Uusin viesti 15 Syyskuu, 2012, 18:02:39
kirjoittanut proffa84
