Kirjoittaja Aihe: Phoenix 3.0  (Luettu 57699 kertaa)
Phoenix 3.0
« : 23 Syyskuu, 2010, 19:51:27 »
Moi,
Hyviä uutisia talvea silmälläpitäen. Phoenix RC on julkaissut 3.0 Beta Releasen. Muutoksia on aika paljon. Itse en varmaan vielä päivitä tässä vaiheessa vaan odottelen muiden käyttäjien toimimista beetta testaajina. Urhoolliset voi laittaa kokemuksia tähän alle. :)
we are pleased to be able to offer the first public beta of the new 3.0 release of phoenix.this update is a self-installing manual update, and can be downloaded from our downloads page.please note that this update currently only includes the english language. more languages will be added very soon leading up to the final release.
New features, Improvements and fixes
• Physics:
• Helicopters:
• New detailed flybarless physics system:
• Choose from Standard, Passive flybarless or Active flybarless systems
• Adjust advanced parameters such as Agility, Response and Gain
• Accurately simulates all low-gain and high-gain flybarless effects such as:
• Retreating blade stalls
• Grabbing
• Wag/bounce
• Active flybarless system with fully configurable self-righting behaviour
• Improved, more accurate flybar physics (e.g. cyclic interaction)
• Increased stability in pirouetting manoeuvres (e.g. Piro-flips/chaos)
• Improved tail-rotor wash profiles
• Improved engine torque/drag curves
• Added rotor-bearing drag for correct behaviour under autorotations
• Various changes and tweaks to model setups and variants
• User Interface:
• New-look user-interface and more themes to choose from
• Huge number of User Interface improvements and tweaks
• New, easier-to-use Widget UI system
• Sort model selection by make, type, etc
• Show actual model names and manufacturers in list
• Added support for extended character-set languages, e.g Russian/Chinese/etc
• Improved translation for all languages
• Onscreen indicator for software functions (i.e. rates, idle-up, throttle-hold, etc)
• Quick Tips on loading screen
• New “Look At” menu under the “View > Camera” menu makes spectating easier
• Launch options:
• Set your preferred launch method for each model
• Choose from:
• Ground launch – for powered models
• Hand launch – new hand-launch system controlled from your radio
• Tow launch – have an AI-controlled pilot tow your glider into the air
• Widgets:
• New Timer widget
• New logbook widget
• Improved onscreen transmitter display
• Improved model > Edit screen:
• Simple and Detailed views
• Easy “Model Setup” control lets you change a model’s general setup
• Clearer editable parameter list
• More description on editable attributes
• Scale Wizard helps you resize models more easily
• New toolbar system for more streamlined interface:
• Notifications bar
• Favourites bar
• Inflight tuning bar
• Graphics:
• Pilots on all model types (planes, helicopters, autogyros, tilt-rotors)
• Multiple pilots on models
• Fixed moving tail and nose wheels
• New water-spray effects
• Improved and optimised water wakes and splashes
• Improved smoke system
• Extra camera zoom option for smaller models
• Improved mouse-wheel zooming
• Controls:
• New software low-rates control for all model types
• New control profiles added
• Buddies:
• Fly with up to 3 computer-controlled pilots
• Set their skill level and model choice
• Intelligent AI avoids you and flies in a realistic manner
• Spectate a buddy and learn from their control movements
• Online:
• More advanced lobby and lobby-chat
• Select your own avatar and see other pilots’ avatars online
• Filter models – choose only to fly with certain model types
• Messenger widget replaced with Multiplayer Toolbar:
• Enhanced chat
• Easier control for hosts
• Competitions:
• All modes revamped with better graphics, user-interfaces and competition logic
• New competition system:
• New “challenge” mode
• Keep your top scores
• Online and offline play
• Clear, easier user-interface and controls
• New Laser Combat mode added
• Layouts:
• Improved layout graphics
• More layouts added
• Improved update system:
• Improved, clearer update browser
• New updates shown more easily
• Icons for updates
• Seperate program update system
Vs: Phoenix 3.0
« Vastaus #1 : 23 Syyskuu, 2010, 20:09:53 »
no johan on lista! kuullostaa hyvältä!
vaan toivottavasti toimii vielä vanhalla uskollisella koneen raadolla!
taitaa tulla kalliiksi tääkin...  :(
Poissa Jerkku
  • Rc-Kopterit Ry
Vs: Phoenix 3.0
« Vastaus #2 : 23 Syyskuu, 2010, 20:50:00 »
Pistin heti tulemaan, aika hitaasti vaan työntää...
Trex 500 ESP  3G
Vs: Phoenix 3.0
« Vastaus #3 : 23 Syyskuu, 2010, 21:01:36 »
Hyvältä näyttää ja tuntuu. Läjä uusia koptereitakin,  550 alignit 3G:llä ja ilman.
Paa asentaen vaan.
Vs: Phoenix 3.0
« Vastaus #4 : 23 Syyskuu, 2010, 21:10:41 »
Toimiiko siinä verkkotoiminto jo?
Vs: Phoenix 3.0
« Vastaus #5 : 23 Syyskuu, 2010, 21:14:12 »
Toimii
Vs: Phoenix 3.0
« Vastaus #6 : 23 Syyskuu, 2010, 22:19:51 »
onko raskaampi koneelle pyörittää (yhtään ku nyt jo mennään kintaalla)?
Vs: Phoenix 3.0
« Vastaus #7 : 23 Syyskuu, 2010, 22:26:08 »
Hitto kun ei pääse vertaamaan mutta perstuntumalla sanoisin että kevyempi.
Vanha piirsi kaksinumeroisia fps lukuja ja tässä mennään reilusti satasen päälle omassa kokoonpanossa.
Vs: Phoenix 3.0
« Vastaus #8 : 23 Syyskuu, 2010, 22:26:58 »
Kohta testiin  8)
Vs: Phoenix 3.0
« Vastaus #9 : 23 Syyskuu, 2010, 22:34:23 »
NO OHO! yllättävää! täytyy koittaa ku pääsee duunista kohta puoleen!
Vs: Phoenix 3.0
« Vastaus #10 : 23 Syyskuu, 2010, 22:37:42 »
Kokeilkaas joku joka ei vielä ole päivittänyt kattoa tota framratea ennen ja jälkeen päivityksen.
Vs: Phoenix 3.0
« Vastaus #11 : 23 Syyskuu, 2010, 22:44:10 »
Lataaa päivitystä... en tiedä muuttuuko framet tällä koneella miksikään..
Poissa Falconi
  • se irkkihemmo
  • Korsee äpterit
    • Kuvasivut
Vs: Phoenix 3.0
« Vastaus #12 : 23 Syyskuu, 2010, 23:06:35 »
En saanut pelittää. Asentaa kyllä päivityksen ja sen jälkeen ilmestyy vaan versio 2.5v. En tajuu, käyttiksenä wintoos 7 64bit.
#kopterit.net@IRCnet
|X5|
Whiskey Tango Foxtrot
Poissa Jerkku
  • Rc-Kopterit Ry
Vs: Phoenix 3.0
« Vastaus #13 : 23 Syyskuu, 2010, 23:15:19 »
Pyörii tälläkin kokoonpanolla loistavasti, korkeimmilla asetuksilla.
Athlon 64 3500+, 3gb, geforce 7800.
Trex 500 ESP  3G
Vs: Phoenix 3.0
« Vastaus #14 : 23 Syyskuu, 2010, 23:35:21 »
tolla setillä syytä pyöriäkkin!
täällä on celeron 2.66GHz, 1Gt, radeon9550 (voi tehä tiukkaa jos vähänki on jotain hienompaa grafiikkaa) ;D
Poissa Falconi
  • se irkkihemmo
  • Korsee äpterit
    • Kuvasivut
Vs: Phoenix 3.0
« Vastaus #15 : 24 Syyskuu, 2010, 00:40:15 »
sain toimii! Eli jostain syystä tuo beetta päivitys halusi asentua ilmeisesti phoenixin oletus kansioon programfiles\phoenix rc\ vaikka valitsin oikean sijainnin siittä. Sitten kopioin käsin noi filut mitä se työnsi tonne väärään paikkaan niin oikeaan asennus hakemistoon. Rupes pelittää ja hienosti pyörii täällä. Tosin läppäriin en laittanut vielä.
Mielestäni tässä on hölmö toi edit homma. esim 500 rekku on aivan liian laiska default 50% asetuksilla ja sit kun ton pykälän lyö tonne 100% niin se tulee yli ärhäkäksi. En saanut vielä toden tuntuista rekkulaa säädeltyä, ehkäpä ensi viikolla kun aikaa liikenee ja on pirteämpi olo.
|X5|
Vs: Phoenix 3.0
« Vastaus #16 : 24 Syyskuu, 2010, 10:30:04 »
ja tekeekin! >:( jostain syystä ruudunpäivitys asettuu taivaalla maks 36fps ja ku maata vilisee ohi niin on vielä sitä vähemmän ja koko paska tökkiin pahasti! jos joku siis ajaa tällasella esihistoriallisella paskalla tota mikä mulla on niin melkein sanoisin että ei kannata tota betaa ihan vielä päivittää ku ei oo pakko! ruudun päivitys nimittäin laskeen karkeesti vajaalla puolella! (sama kenttä, sama kepakko, samat asetukset) >:(
e. paremmat FPSt kuullostikin jo tarkemmin ajateltuna liian hyviltä ja ehin vähä turhaan innostua :(
Vs: Phoenix 3.0
« Vastaus #17 : 24 Syyskuu, 2010, 10:34:13 »
Paremmat FPS:t on voitu saada aikaiseksi hyödyntämällä paremmin uudempien grafiikkakorttien laskentaominaisuuksia, mutta ne ovat voineet samalla hidastaa käsittelyä nillä näyttiksillä, jotka eivät kyseisiä ominaisuuksia tue.
Vs: Phoenix 3.0
« Vastaus #18 : 24 Syyskuu, 2010, 10:36:33 »
tähän tulokseen mäki tulin!
Poissa Mick
Vs: Phoenix 3.0
« Vastaus #19 : 24 Syyskuu, 2010, 12:10:00 »
Mulla tilttaa toi samantien kun yritän vaihtaa helikopterin käyttöön...FUU!
Spartan
Phoenix Rc
Vs: Phoenix 3.0
« Vastaus #20 : 24 Syyskuu, 2010, 12:24:32 »
Näin varmaan juu.
Mä tipuin rautakärryiltä silloin kuin tuli edo-rammit..   mutta tässä tämän läppärin "speksejä" millä veivaan
ATI Mobility Radeon HD 2600
Intel Core2 Duo T9300@2.5GHz
32 bit Vista ja 4Gigaa muistia.
VSYNC päällä pitää tuon 60fps 1440x900 fullscreen tilassa. Anti-alias toki  pois päältä.
Ilman v-synciä 100-140fps  high-asetukset kaikessa.
Poissa Miika
Vs: Phoenix 3.0
« Vastaus #21 : 24 Syyskuu, 2010, 14:39:32 »
Lista on komia noiden päivitysten osalta, mutta eivätkö ole VIELÄKÄÄN saaneet aikaiseksi VPP-lennokkia?
Eli siis lennokkia jolla voisi myös lentää nokka alaspäin.
Nyt päivitystä lataamaan!!
Poissa artta
  • Parolan LK
Vs: Phoenix 3.0
« Vastaus #22 : 24 Syyskuu, 2010, 20:02:51 »
Eipä toimi ei. Beta mikä beta. Kaatuu heti päivitysilmoitukseen. Rautana core2duo 1.6, 2 Gt, GMA950.
Odotellaan seuraavaa versiota.
Futaba 8FG
Poissa Quinn
  • Jäsen nro. 88
Vs: Phoenix 3.0
« Vastaus #23 : 24 Syyskuu, 2010, 20:09:46 »
Minulla on sellainen ongelma Phoenixissa, että jos laittaa vertical syncin päälle asetuksista ja käyttää full screen -modea, ruudunpäivitys tipahtaa ryömintänopeuksille <15 fps. Jos taas ajaa vertical sync päällä ikkuna-moodissa, niin ruudunpäivitys pysyy naulattuna 60 fps kuten pitääkin. Vertical syncin jos ottaa pois, niin fps on ~150-200 kummassakin tilassa. Tykkään kuitenkin pitää sitä päällä, kun välillä tulee screen tearia, vaikka olisi minkälaiset äfpeeässät. Eivät keksineet Phoenixillakaan, mikä tuon aiheuttaa, kun kyselin viime syksynä. Samaa tekee tässä 3.0 betassakin.
Vanhalla koneella ei tuota ongelmaa ollut. Nykyisiä speksejä: Intel Core i7 860, 2x2 Gt Corsair Dominator DDR3 1600 MHz, Asus P7P55D Deluxe, Club 3d Radeon HD 4890 Super OC 1GB, Windows 7 64-bit, HP zr24w-näyttö.
Lama V3 isolla kasalla päivitysosia
Blade mSR BNF
Phoenix RC
iCharger 106B+ & P350-poweri
Vs: Phoenix 3.0
« Vastaus #24 : 24 Syyskuu, 2010, 22:36:48 »
Jussin suositusten mukaan uskalsin päivittää tohon uusimpaan. About tunnin lennättelin tolla version 3:lla ja ei mitään ongelmia. Selvää parannusta jälleen, sillä nyt ovat saaneet paremmin mallinnettua kopterin massaa. Myöskin yleinen käytettävyys on sujuvampaa ja kaverit lista on hyvä parannus. Jokatapauksessa lennättäjälle toi fysiikan parannus on se tärkein. Jatketaan.
10255 Lukukerrat
Uusin viesti 24 Heinäkuu, 2014, 13:37:54
kirjoittanut Nalle Puh
3714 Lukukerrat
Uusin viesti 21 Joulukuu, 2014, 11:58:27
22 Vastauksia
11807 Lukukerrat
Uusin viesti 14 Maaliskuu, 2019, 20:38:41
2831 Lukukerrat
Uusin viesti 01 Joulukuu, 2021, 12:44:33
kirjoittanut maulau
5257 Lukukerrat
Uusin viesti 16 Tammikuu, 2022, 22:34:58
kirjoittanut Ripa
