Stall Turns Banked Turns Getting started with piroflips Kaos! Practising efficiently One-trick dogs Variations Variations exercise Segments and transitions 3D variations A simple recipe... Making the most of the simulator Exercises Under construction Drill Instructor
previous: One-trick dogs next: Variations exercise
This page is under construction. Don't believe every word :-)
Variations
One technique to come up with new challenges is to practise variations of moves you know.
Most important: Learning n variations does not take n times the effort. Far from it. For example, my guess is that tackling all 8 forwards flight variations requires about two or three times the effort, compared to one direction. You'll almost get the final ones "for free".
The common options are:
Hovering:
  • Location: Left-right, forwards-backwards, up-down. Hover in different directions without turning your body
  • Movement: Move controlled between locations
  • Angle: Master nose-in, side-in and all 12 directions, like hours on a clockface.
  • Piro: Learn to hover piroing slowly left and right
Forwards flight
  • Figure 8 with the cross-over facing away (this is IMO the easiest and probably safest variant).
  • Figure 8 with the cross-over facing towards the pilot
  • Left-hand circles
  • Right-hand circles
  • The same backwards
  • The same nose-in
  • The same tail-in
This may look like a lot of work. It is, but you have to learn them anyway. My point is simply, learn them systematically and save time.
 I should mention that I did the forwards flight program myself three years ago, exactly as described here.
Stall turns
  • First forwards, and a while later in all four directions
Loops
  • First forwards, and finally in all four directions
Inverted
You guessed it: All the hovering, but skids up. Then the forwards flight program.
Again, I "beta-tested" this program myself. It is a lot of work, but I don't think there is a better way.
Piroing
And this is where the learning curve skyrockets.
For me, the hovering exercises (piroing hover just moving left-to-right and back) felt the hardest.
Piroing stall turns are an extremely valuable exercise, few people ever mention this.
Thanks to kopterit.net for hosting this page.
The content of this page is copyrighted and may not be reproduced without written permission.
