Stall Turns Lazy stall turns Videos Exercises Flying them nicely Practising in the sim 90-degree stall turns Setup How to continue Banked Turns Getting started with piroflips Kaos! Practising efficiently Making the most of the simulator Exercises Under construction Drill Instructor
previous: Exercises next: Practising in the sim
This page is under construction. Don't believe every word :-)
It is a good idea to already now pay attention to the details:
  • The fly-by should be straight, at constant altitude and speed.
  • Try to achieve well-defined transitions between the segments
  • Think of the turns 2) and 6) as separate segments: In my head, the "program" for a stall turn might look like this:
    "straight ahead --- pull --- straight up --- piro --- straight down --- pull --- straight ahead".
  • During exit, try to mirror the entry path.
  • Keep an eye on altitude and straightness during ascent and descent: It will take careful collective corrections to give the illusion that the heli is gliding up and down an invisible slope.
Here are some more exercises. Those work very conveniently with a simulator - those who don't have two screens can easily use Alt-Tab back to switch back and forth between sim and this "workbook":
Polish your lazy stallturns:
mouse over the boxes below!
feature: Straight line in fly-by
sim:
real:
feature: flyby at consistent distance
sim:
real:
feature: constant flyby speed
sim:
real:
feature: clearly defined transition into ascent
sim:
real:
feature: left and right side work equally well. The peak altitude is about the same.
sim:
real:
feature: The heli ascends on a straight line
sim:
real:
feature: The heli does not sag or drift away at the turnaround point
sim:
real:
feature: The descent is straight and matches the entry path
sim:
real:
feature: The transition from descent to straight line is crisp and round. The heli doesn't bounce or sag, but exits in a straight line parallel to the ground
sim:
real:
feature: The stall turns (ascent) don't lean towards the flight line or away from it.
sim:
real:
Thanks to kopterit.net for hosting this page.
The content of this page is copyrighted and may not be reproduced without written permission.
