|  Stall Turns
Lazy stall turns
Videos
Exercises
Flying them nicely
Practising in the sim
90-degree stall turns
Setup
How to continue
Banked Turns
Getting started with piroflips
Kaos!
Practising efficiently
Making the most of the simulator
Exercises
Under construction
Drill Instructor
 | This
page is under construction. Don't believe every word :-)
 How to continueThere is an endless number of possible variations.
  Level out at the top and stop. Piro slowly 180 degrees
while hovering, stop. Quarter flip forwards and down we go.180+360 degree piropiro 360 degrees in one direction, and then 180 in the other
| Stall turns aren't boring! |  | mouse over the boxes below! |
| during the vertical part, piro as early and as slowly as possible. The heli should use as much time for piroing as possible. |   |  |
| don't piro at the turnaround point, but wait well into the descending part. Flown well, this can look quite impressive. |   |  |
| piro 360 degrees, then 180 in the other direction |   |  |
| slow piro all along the straight segment (this is quite hard) |   |  |
| fly huge stall turns, with particular attention to the segments being straight |   |  |
| stop at the top of the stall turn, hover and piro around |   |  |
| combine the stall turn with a roll in the straight-line segment |   |  |
| fly a roll into the descending part |   |  |
| omit the piro (or do 360 degrees), push over and fly away in the other direction |   |  |
|  |  For a 3D pilot, stall turns are a great exercise to master any "flight
mode":
  A backwards inverted stall turn (tail slide) is one of the staples in
3D flying.backwardsside-in
and all four directions inverted
piroing, both upright and inverted The piroing variants are very challenging, but rewarding: It is
spectacular when the piroing heli drops vertically and pulls out. And,
mistakes get even more spectacular.
